07-23-2021 06:59 AM
I'm trying to use the entSensorThresholds OID to collect the thresholds for optical SFP Modules, but having issues when IOS XE is installed. On old devices with IOS everything is working.
Examples:
WS-C3750X-12S-E / IOS 15.2(4)E10 / Gi1/0/1 -> GLC-SX-MMD
Switch# sh inventory [...] NAME: "1", DESCR: "WS-C3750X-12S" PID: WS-C3750X-12S-E , VID: V04 , SN: *** [...] NAME: "GigabitEthernet1/0/1", DESCR: "1000BaseSX SFP" PID: GLC-SX-MMD , VID: V01 , SN: *** [...] # find interface (entPhysicalDescr) snmpwalk [...] 1.3.6.1.2.1.47.1.1.1.1.2 | grep 'GigabitEthernet1/0/1 .*Power Sensor' SNMPv2-SMI::mib-2.47.1.1.1.1.2.1044 = STRING: "GigabitEthernet1/0/1 Transmit Power Sensor" SNMPv2-SMI::mib-2.47.1.1.1.1.2.1045 = STRING: "GigabitEthernet1/0/1 Receive Power Sensor" # get current value (entSensorValue) snmpwalk [...] 1.3.6.1.4.1.9.9.91.1.1.1.1.4 | egrep '\.1044|\.1055' SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.1044 = INTEGER: -51 SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.1055 = INTEGER: 72 # get threshold values (entSensorThresholdValue) snmpwalk [...] 1.3.6.1.4.1.9.9.91.1.2.1.1.4 | egrep '\.1044|\.1055' SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1044.1 = INTEGER: 0 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1044.2 = INTEGER: -30 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1044.3 = INTEGER: -95 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1044.4 = INTEGER: -135 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1055.1 = INTEGER: 150 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1055.2 = INTEGER: 120 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1055.3 = INTEGER: 20 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1055.4 = INTEGER: 10
WS-C3850-12S-E / IOS XE 16.12.4 / Gi1/0/1 -> GLC-SX-MMD
Switch# sh inventory [...] NAME: "Switch 1", DESCR: "WS-C3850-12S-E" PID: WS-C3850-12S-E , VID: V02 , SN: *** [...] NAME: "Gi1/0/1", DESCR: "1000BaseSX SFP" PID: GLC-SX-MMD , VID: V03 , SN: *** [...] # find interface (entPhysicalDescr) snmpwalk [...] 1.3.6.1.2.1.47.1.1.1.1.2 | grep 'GigabitEthernet1/0/1 .*Power Sensor' SNMPv2-SMI::mib-2.47.1.1.1.1.2.1078 = STRING: "GigabitEthernet1/0/1 Transmit Power Sensor" SNMPv2-SMI::mib-2.47.1.1.1.1.2.1079 = STRING: "GigabitEthernet1/0/1 Receive Power Sensor" # get current value (entSensorValue) snmpwalk [...] 1.3.6.1.4.1.9.9.91.1.1.1.1.4 | egrep '\.1078|\.1079' SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.1078 = INTEGER: -60 SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.1079 = INTEGER: -52 # get threshold values (entSensorThresholdValue) snmpwalk [...] 1.3.6.1.4.1.9.9.91.1.2.1.1.4 | egrep '\.1078|\.1079' ### noting ### # as another proove, get threshold value for specific index (entSensorThresholdValue.1078) snmpget -f [...] 1.3.6.1.4.1.9.9.91.1.2.1.1.4.1078 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1078 = No Such Instance currently exists at this OID
C9300-24S / IOS XE 17.3.3 / Gi1/0/1 -> GLC-SX-MMD
Switch# sh inventory [...] NAME: "Switch 1", DESCR: "C9300-24S" PID: C9300-24S , VID: V01 , SN: *** [...] NAME: "Gi1/0/1", DESCR: "1000BaseSX SFP" PID: GLC-SX-MMD , VID: V01 , SN: *** [...] # find interface (entPhysicalDescr) snmpwalk [...] 1.3.6.1.2.1.47.1.1.1.1.2 | grep 'GigabitEthernet1/0/1 .*Power Sensor' SNMPv2-SMI::mib-2.47.1.1.1.1.2.1090 = STRING: "GigabitEthernet1/0/1 Transmit Power Sensor" SNMPv2-SMI::mib-2.47.1.1.1.1.2.1091 = STRING: "GigabitEthernet1/0/1 Receive Power Sensor" # get current value (entSensorValue) snmpwalk [...] 1.3.6.1.4.1.9.9.91.1.1.1.1.4 | egrep '\.1090|\.1091' SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.1090 = INTEGER: -50 SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.1091 = INTEGER: -264 # get threshold values (entSensorThresholdValue) snmpwalk [...] 1.3.6.1.4.1.9.9.91.1.2.1.1.4 | egrep '\.1090|\.1091' ### noting ### # as another proove, get threshold value for specific index (entSensorThresholdValue.1090) snmpget -f [...] 1.3.6.1.4.1.9.9.91.1.2.1.1.4.1090 SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.1090 = No Such Instance currently exists at this OID
So as you can see, the first example, with IOS, is working for entSensorThresholds. But the other two examples aren't working. You can still obtain the current value, but not the thresholds.
Am I doing somthing wrong? Have I missed something? Or is this a bug?
Thnak you.
Solved! Go to Solution.
07-26-2021 07:04 AM
I've opened a TAC case and got following answer.
I did some research and it's confirmed that detailed SFP information given by entSensorThresholdTable is not supported on C3850 and C9300 IOS XE releases so far.
Also, there's an enhancement request opened for it, so the support for this can be included in future release.
You can subscribe to it by clicking in the "Notifications" button, this way you will be receiving periodically updates about the status.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn58055
07-26-2021 07:04 AM
