04-17-2018 08:21 AM - edited 03-01-2019 06:32 PM
Hello all and thanks for your time and expertise. In the past where I work when they setup a building with new APs they would create VLANs for the AP and the WIFI traffic. They would assign a separate native VLAN for the APs and allow the AP and WIFI VLANs for the APs as well.
For the WIFI traffic they would also allow the AP and WIFI VLANs. And the IP Helper would be added to both VLANs.
What I'm noticing in DHCP is that the scope for the APs also includes devices like phones, laptops, etc instead of just exclusively APs.
Is there something that has to be done, or should be done, so the scope for the APs only assigns IP Addresses to the APs.
Anyway, I'd appreciate your recommendations and input.
Solved! Go to Solution.
04-17-2018 08:40 AM
- Depends on the current setup , if all autonomous AP's are used, then a DCHP server can contain all addresses , including those of the AP's and clients ; but if you have lot's of AP's this architecture won't scale (indeed). Better is then to have a centralized (controller) based setup where the AP's become managed by a wireless controller. Traffic from the clients is then tunneled to and from the controller (CAWAP), who also terminates the VLAN's. -> Intermediate architectures are also possible.
M.
04-17-2018 08:40 AM
M.
