Hello All,
We are planning to implement SNMP monitoring in our network. Are there any recommended SNMP traps that should be enabled on the devices so we dont get clobbered with thousands of traps.
We have the following devices on our network-
Cisco 7206 with ATM interface, running BGP, EIGRP, PBR.
Cisco 6509, 6513 switches- Running EIGRP, Cisco FWSM
Cisco 1841 routers- have serial links, running BGP, Frame relay.
Cisco 2800 router- acting as DHCP server
Cisco ASA - 1) Perimiter firewall, 2) SSLVPN firewall.
We wish to monitor not only the external parameters like the circuits, routing protocols etc,, but also hardware and environmental parameters if possible.
If someone can recommend a list of traps that should be enabled for these devices, I wold much appreciate it.
Imran.
