01-21-2016 06:21 PM
Apologies if I have the title incorrect but here's my question. I've been doing network in the past couple of months and our traditional setup was an L2 switch cascaded or trunk in an L3 switch. What if for example, I purchased another L3 switch and from the L2 switch interconnect 2 cables going to both L3 switch. The purpose is for redundancy in case the first L3 broke down.
Jeff
Solved! Go to Solution.
01-22-2016 12:49 PM
Buy a second 3850 and stack them together. That makes them look like one switch.
Then connect each 2960 to both Cisco 3850's using Etherchannel.
01-26-2016 06:29 PM
2960-X does not have HSRP.
01-21-2016 10:46 PM
01-22-2016 12:37 AM
for the L3 is 3850 while for the L2 are 2960-X or -S
Jeff
01-22-2016 12:49 PM
01-26-2016 06:28 PM
Not sure if I can inject this quick question, haha, correct me if I'm wrong guys, 2960-X switches cant perform HSRP or redundancy, right?
Jeff
01-26-2016 06:29 PM
02-01-2016 07:23 PM
thanks for the input p.dath.
Have a great day ahead!
Jeff
