Oh yeah, I just tested it. It is as easy as other jobs.
I actually asked this question, because when you want to reload the router, you need to press on Enter to confirm the reload, which can not be done by Ciscoworks (oressing Enter), but I just tested with a template with "reload" command, and it worked fine.
I should have tested before asking ;-)
Thanks anyway for your help.
Mehdi
