Removing devices from aniserver
brettevans34
I'm currently using Ciscowork2000 4th edition.
I have recently changed the IP address of a couple of cisco switches. The aniserver has discovered the new ip addresses for these switches, but it is also showing the old IP addresses aswell in (server configuration>discovery metrics).
Any ideas on how I can delete or stop it discovery the old IP addresses
thanks
steve.busby
Level 5
Level 5
Sure, go into campus manager and delete the old device IPs. Also, ensure you're not using the old IPs as seed devices.
