02-19-2020 01:32 PM
Would anyone know how to remove the location configuration "location civic-location-id none" from an interface?
interface GigabitEthernet1/0/16
I have tried "no location civic-location-id none" and defaulted the interface but the configs stays on the interface..
02-19-2020 03:51 PM
what is the device model and what IOS code it running.
can you post after default the interface
show run inter gi 1/0/16 ?
10-13-2020 10:41 AM
After a default interface gi 1/0/44
Building configuration...
Current configuration : 72 bytes
interface GigabitEthernet1/0/44
end
06-02-2023 06:36 AM
I've got this problem too which causes our phones not to work in the ports where this is configured.
If i go into the config mode of the port and run a
The config is still on the port. I've tried creating a location id of 1, associating that to the port and then running the command but it reverts back to
Where I want to get rid of that bit of config altogether from the interface.
Does anyone know how?
