Hi Team,
We would like to request your technical assistance for the diagram attached . As you can see in the diagram, the IE-3000-4TC-E will be powered via 230VAC to 24VDC power supply module.
Also, there is a requirement to add the IEM-3000-4PC.
- Just want to check if we still require to have the PWR-IE65W-PC-AC to power up the IEM-3000-4PC?
- or the two PWR-IE50W-AC is sufficient to support the power requirement of the IE-3000-4TC-E plus IEM-3000-4-PC configuration below?
