Required comparision for old and new cisco devices
vikky sahare
Beginner
Beginner
Hi Team,
We have decided to replace current cisco devices with new model and need help for comparison between Old and New devices with below required details,
Required Details :-
1) Number of port(ex. 48)
2) Interface speed(ex. 1Gbps)
3) Interface geometry(ex. RJ-45/SFP)"
4) DRAM
5) Flash memory
6) Rack Unit/mount
7) Dimensions (H x W x D)
Power supply
9) Power consumption
Old Devices                                                          New Devices
Catalyst6807-XL                                                  Catalyst9400 and Catalyst9600
Catalyst2960X & Catalyst2960CX                         Catalyst9200 and Catalyst9300
Catalyst3850                                                        Catalyst9300
ASA5585-X                                                          Firepower 4112(ASA mode)
 Unless someone here did this work and will be kind anough to share here, you need to go to each Data sheet and do it yourself.  If I had, I would share but I hadn´t to do this so far.
 I would create a spreadsheet with all the device side by side and every requirement on the list and then using the Datasheet I would  go filling in every requirement. At the end you have a grasp of each one´s capacity and differences.
