resend captured packets from cisco ios? (tcpreplay w/o WireShark)
carrollha
Hello again,
As the title of the thread implies, is there a way to replay captured packets (as in a pcap file from the EPC protocol) from cisco ios? I am trying a work around by calling it from a connected computer, but I can't launch tcpreplay dynamically from an EEM script (mainly because I can't target the host OS from the EEM scope).
Basically I am capturing packets in order to delay them until some arbitrary time determined by another (or even the same) EEM script. Is there a function I don't know about that I can call to put previously captured packets (stored in a pcap file) directly back on the bus as if nothing happened?
Thanks in advance,
-Heath
Joe Clarke
You can't replay packets right now.  The upcoming onePK APIs will allow you to do this, however.  If you want to call tcpreplay from your EEM policy, you could send a trap to the host, which triggers the excution, or use the Remote Command Shell policy from http://www.cisco.com/go/easy to telnet/SSH to the host from the device to run the command.
Joe Clarke
That response is chock full of WIN. Thank you for pointing me to onePK. It looks like a great solution to my current multi-platform/router hackeneyed approach. The Remote Command Shell policy is pretty sweet, too.
Thanks!
