Resetting or changing password on access point
Beenemon2k2
I have a Cisco CBW140AC-B, but I do have a Cisco router or switch. I was successful in setting up the APs but I need to change the password and SSID because of a security risk, but I am unable to access the APs to do so. What can I do?
Beenemon2k2
 For what reason you can not access the access point? And how are you trying to access it? Depending on your answer, the solution would be factory reset it.
Beenemon2k2
Well I set up the APs by plugging into the console port or it might have been via a browser, it has been a while. I tried using the mode button to reset but it has not defaulted to factory settings.I did not have a Cisco Router or Switch or controller.
This AP allows for console configuration. Try to find the cable and let me know if I can help you with the config
