03-07-2011 12:05 PM
I want to test the hostname to IP resolution i want to use thecommand (NMSROOT/bin/perl NMSROOT/bin/resolver.pl IP ) for testing, My lms is installed in D:/CISCO WORKS folder i tried by applying command but i get the following error.Can anybody help me to write the exact command
D:\Program Files\CSCOpx\bin>perl d:\CSCOpx\bin\resolver.pl 192.168.2.126
Can't open perl script "d:\CSCOpx\bin\resolver.pl": No such file or directory
Solved! Go to Solution.
03-07-2011 12:11 PM
It seems you are using the incorrect path. The correct path\command as per the your install dir should be :
D:\Program Files\CSCOpx\bin>perl d:\Progra~1\CSCOpx\bin\resolver.pl 192.168.2.126
Though if you are already CD'd to NMSROOT\bin you can simply run NMSROOT\bin>perl resolver.pl
Example (from my server):
C:\Program Files\CSCOpx\bin>perl resolver.pl cisco-nms
Original name: cisco-nms
Hostnames/IP Addresses:
cisco-nms/10.78.141.29
03-07-2011 12:11 PM
03-08-2011 11:04 AM
Thanks Dear,
