Restore LMS 3.1 to 3.2
Mario Elia
Evening,
I am hoping to upgrade my LMS from 3.1 to 3.2 very soon. I have created a backup using NMSROOT/bin/perl backup.pl, and that has completed successfully (took a few tries, but it worked).
With this backup that I now have, can I restore it once I install 3.2 (I will be doing a clean install, not an upgrade)
2 Accepted Solutions
Yes.  And you should reboot before starting the 3.2 installation.
5 Replies 5
Joe Clarke
Thank you jclarke,
Your answer is exactly what I was looking for.
Thanks again.
One more quick question;
Once the un-installation of 3.1 is complete, there is still a CSCOpx folder in my Program Files (Windows 2003).
Should/Can I delete that before I install 3.2?
Thank you once again, jclarke.
I hope they pay you well!
