Restorebackup.pl failure
woods8
I have run a scheduled weekly backup from Common Services>Server>Admin>Backup for sometime now.
I now have to prove the backups work.
I have run the restorebackup.pl command and runs ok for a good while then I get the following message flashing on my monitor:
ERROR: Unable to close LOG_HANDLER
ERROR: Error in extracting single file.
Any advice on this as I have tried this 3 times but to no avail?
There is no relevant info in the restore logs either.
When I stop the ERROR: Unable to close LOG_HANDLER
I then get ERROR: Error in executing the tar command [-1]
ERROR: Unable to delete directory g:\CISCOW~1.5\tempBackupData in deleteDirector
y()
Restore failed.
I run LMS2.5, CS 3.0.4, CM 4.0.4, DFM 2.0.3, RME 4.0.4 on a Windows 2000 server.
I do hope someone can shed some light on the matter.
Thanx in advance.
David Stanford
Does casuser or the casusers group have full control over the directory g:\CISCOW~1.5\ and its contents?
Prior to this backup were you able to restore previously? Are there any other errors in the restorebackup.log?
I have now managed to restore the backup.
I had the backed up folder on a different disk partition to that of the Ciscoworks install partition. I just moved over the backedup files to the ciscoworks partition and "voila" it worked.
thanx for your prev. post davistan
Check the restorebackup.log in the NMSROOT\log folder.
I guess space was an issue but the file will tell you
Cheers,
Michel
I guess disk space or proper rights was the issue.
Cheers,
Michel
