RME 4.0.6, problem with authorization
Volker Janusch
Level 4
Level 4
after installing LMS 2.6, the rme-homepage shows the following error:
"You are not authorized to view the details" (see attachment). I recovered the password with "dbpasswd.pl", but without solution.
I do not why. Please help me.
Kind regards.
Volker
Manager DC-Networking, Automation & WLAN
Logicalis GmbH
12 Replies 12
Joe Clarke
Is this server integrated with ACS?
No, this server is not integrated with ACS. The local user "admin" has all credentials.
Logicalis GmbH
Any Idea?
Logicalis GmbH
Please post the output of the pdshow command.
the attachment contains output of "pdshow".
Logicalis GmbH
Please post the Tomcat stdout.log under NMSROOT/MDC/tomcat/logs.
stdout.log
Regards.
Logicalis GmbH
Did you ever resolve this as I have a similar issue ?
Please start a new thread for your issue.
I missed this attachment. Your problem is being caused by either a bad regdaemon.xml, or a bad role map file. If you are still seeing this problem, I will need to see your NMSROOT/MDC/etc/regdaemon.xml file.
Im seeing the following error message in the the Tomcat logs
DEBUG:appID for context:/rme from CCR:rme
[Sun Jan 04 06:33:16 GMT 2009] Authorization failed for user admin due to some internal error. Error = Unable to process CMF role file for application: rme
Unable to authorize user: admin
[Sun Jan 04 06:33:16 GMT 2009] The User admin is not allowed[Ljava.lang.String;@9e8310
[Sun Jan 04 06:33:16 GMT 2009] UII Tasks found! Lookup for CAM Tasks and then call CAM APIS!
[Sun Jan 04 06:33:16 GMT 2009] Task name RME_JOBS_DC_JOBS found in the UII Tasks XML file. Fetching the privileges!
Please start a new thread for your problem.
