10-15-2008 01:25 AM
Using LMS 3.0.1 with RME 4.1.1 I get an error when trying to distribute images.
It's same whether I used "By device" or "by image".The recommendation are run for 90 seconds and then the result are always "failure".I've tried different devices&images.All recommendation filters are deactivated.
10-15-2008 10:53 AM
What is the generic error message you are receiving? Have you attempted to enable debugging prior to running the job?
10-16-2008 12:43 AM
After the recommendation phase is finished, there's a status of "failure" in the status field.If I click on the the failure status to get more information, "generic error" is the only thing in the details.I had debug activated and the swim_debug shows that the recommendation times out
[ ti okt 14 13:47:56 CEST 2008 ],DEBUG,[rmeng:RecommendDriver-Monitor-Thread-448],com.cisco.nm.rmeng.swim.drivers.RecommendDriver$Monitor,run,1257,Recommendation has TimedOut for the device :seasbgsw99is90462
[ ti okt 14 13:47:56 CEST 2008 ],DEBUG,[rmeng:RecommendDriver-Monitor-Thread-448],com.cisco.nm.rmeng.swim.drivers.RecommendDriver,setRecommendErrorResult,820,Entering setRecommendErrorResult
[ ti okt 14 13:47:56 CEST 2008 ],DEBUG,[rmeng:RecommendDriver-Monitor-Thread-448],com.cisco.nm.rmeng.swim.drivers.RecommendDriver,setRecommendErrorResult,865,returning from setRecommendErrorResult
[ ti okt 14 13:47:56 CEST 2008 ],DEBUG,[rmeng:RecommendDriver-Monitor-Thread-448],com.cisco.nm.rmeng.swim.drivers.RecommendDriver$Monitor,run,1266,TimeOut result added to monitorlist with Failure Status forseasbgsw99
04-20-2011 10:03 AM
we are having the same issue. You were able to solve it?
Thank you.
Br
