RME 4.3.1 config compare problem
Mason Tu
Beginner
Beginner
Dears,
I am using LMS 3.2 with RME 4.3.1
And I use config compare function in RME to compare two versions of one device.
When I try to show diff only of two different versions.(You may see the result in attached file)
There is the same line marked as blue(ex:permit IP 172.21.22.46 0.0.0.1 any)
Maybe because this line has been deleted and added before.( I am not sure because these lines were modified by QPM )
But in my opinion, this line should be marked as black since the line is exact the same in both versions.
Is this a bug of RME or it's a normal result?
Thanks for any response.
Joe Clarke
This looks okay as ACLs are order-sensitive.  Just because an ACE is present in two ACLs does not mean the meaning of the ACE is the same in both.  RME's config comparison is context-sensitive, so it is telling you that the meaning of these two ACEs is different.
