RME baseline templates
Valery.Laptev_2
I have switches and routers.
Im trying to manadge them from rme 4.2.
I would like to run comand in global mode:
ntp server 10.1.1.100
but only on the devices, which dont have already running:
sntp server 10.1.1.100
my template is:
Name: DefaultPreReq     SubMode: No      isPrerequisite: Yes
Ordered : No     Prerequisite-Commandset : none     Parent: none
  -   sntp   server  [#.*#]
Name: Commands     SubMode: No      isPrerequisite: No
Ordered : No     Prerequisite-Commandset : DefaultPreReq     Parent: none
  +   ntp   server   10.1.1.100
Pleas help...
9 Replies 9
Valery.Laptev_2
it does not work.
the comand do not run on selected devices...
Joe Clarke
You are seeing my bug CSCsv25190.  This bug is fixed in RME 4.3 (LMS 3.2), and a patch for RME 4.2 is available from TAC.  Essentially, negative prerequisites do not work.
As I understand:
on RME 4.2 negative prprerequisites do not work.
on RME 4.3 negative prprerequisites work.
And to fiix the problem, I should use patch 4.3?
The recommended fix is to upgrade to LMS 3.2 which includes RME 4.3.
Thank you for help!!!
Last Q-tion is:
If i have licens for LMS3.1      300 devices.
Should I buy new licens to instal LMS 3.2???
You do not need a new license for LMS 3.2.  Your existing LMS 3.1 license will work just fine.
Good Day!
Were from I can download LMS 3.2 ???
I have used "search", but coulden"t get the correct result.
Pleas, recomend me link to download:)
Go to http://www.cisco.com/go/nmsevals
The evaluation package is in fact a full install but with an evaluation license.
Your current license will overide that.
Cheers,
Michel
Fank you so much)
I am, already downloading LMS 3.2
