05-18-2011 07:34 AM
When I change the default job result wait time settings of 120 seconds to 240 seconds it takes the new settings successfully but doesn't reflect the change later, it's just back to 120 sec what could be the issue. Thanks in Advance for any assistance.
05-21-2011 01:38 PM
This is likely a problem with your regdaemon.xml file containing two entries for the job timeout setting. If you post this file, it should be easy to fix it.
05-23-2011 10:37 AM
thanks for the response. according to regdeamon.xml the change reflect correctly which is "300"sec. and when I tested my slower devices start archiving. so that confirm it's working. so I don't know why this change reflect on GUI. anyways as long as it's working I am just fine. dcma_sync_job_fetch_time 300 1
05-23-2011 11:15 AM
My bet is that there are two entries in regdaemon.xml for dcma_sync_job_fetch_time. One is the correct value, and one is the original. Removing the dup is tricky, so if you find a dup, post the file, and I can clean it up.
05-23-2011 02:39 PM
300
120
you are correct!! there are duplicate entry. is there any easy way I can remove that? for security reason I can't post the whole file or should I open tac case thanks!!
