10-27-2004 06:09 AM
I have a pretty elderly Ciscoworks installation and after suffering from a corrupt database I am trying to build a new one on my Ciscoworks installation. I have, as advised,used the original files to create a new blank database into which I'm trying to import a CSV format inventory from another NMS but this is failing because the database is not responding. I want to check I have the correct login details in the System DSN setup in ODBC for this database. So, can anyone advise what the default dba passwrod is?
RME version 3.2 and CD1 3rd Edition.
10-27-2004 06:23 AM
I am not sure what the default password is for the RME database if there is one.
It sounds like though you are at a stage where you could blow away your database again and create a new one with a new password.
/opt/CSCOpx/bin/perl /opt/CSCOpx/bin/dbRestoreOrig.pl dsn=rme dmprefix=Essentials npwd=*your-new-password*
I did this on a Solaris box over the weekend using the following link:
Paddy
10-27-2004 07:41 AM
01-04-2005 04:31 AM
try c2kY2k
