RME Package
BlueyVIII
Beginner
Beginner
I'm trying to upgrade the RME package for our WLC's but having no success. When I go CS and Device Update then chosse the WLC package it fails and asks me to check the event log.
In the Event Log I see the message "ERROR: Error while installing (WLC): d:PROGRA~1CSCOpx emppsuinstall
meWLC.zip cannot be installed because, the current mdf version:1.32 is LESS THAN the minimum required mdf version:1.37" - Any idea's how I can get version 1.37 so that I can then upgrade?
We're using LMS3.2, CS 3.3.0 and RME 4.3.1
Thanks for any help.
AFROJ AHMAD
Hi ,
Upgarde the MDF Pacakge :
go  to common service > software center > device update >click on   CiscoWorks Common Services .. check for MDF version > upgarde it to  atleast 1.50 ..
Once you upgarde  the MDF  then try to upgarde the Device Packages for RME and see how it works !!!
Common  service > software center > device update > check the check  box for Resource Manager Essentials > click on check for updates and  Installed all the Device Packages !!!
Thanks--
Afroj
If this post answers your question, please click the "Correct Answer" button"
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi ,
Thanks--
Afroj
Recognize Your Peers
