router a and b communicate with router c by network 192.168.102\24
Bruno_Carvalho
im doing my ccna certification study and need some help
i have 3 routers with several networks but i want router a and b to communicate with c by network 192.168.102\24
all of 3 know this network but they have to communicate between them through this network 102\24
they work as a production routers with acls and nats and redundancy etc.
my problem is to create a mental flowchart to the resolution, because i know how to troubleshooting but i cant create the flowchart in my head.
So what do i need to do? check acls? create a static route? or try to ping vlan1 on the 3 routers?
Can anyone help me please??
post a diagram of your topology, as well as the full running configs of all three routers...
Bruno_Carvalho
topology is a mpls connection between 3 routers in a triangle shape, check attached file, the configs are to big to post here. i just found the solution to the problem. i just had to check connectivity with a machine on the destination lan my issue was i had no info on a ip on the destination lan.
thank you for your quick reply @Georg Pauwen
@Bruno_Carvalho wrote: Telldunkin
Great idea man thanks keep it up all the time. am very happy to see your standard.
