Router not following Config
dgragg002
Beginner
Beginner
I have a 2911 that has had a QOS policy on it for about a year.
About a week now I have noticed that the traffic is no longer being tagged as per the QOS assigned to the port.
It is setting many items to default when I am assigning an EF or other rating to them .
If I take the QOS off the port it will pass the incoming QOS through.
I have 5 other 2911s with the same QOS on them and they are all working correctly.
And I went through and compared configs to verify.
One example is  our Video traffic we call ZOOM. It is always on port 8801 or 8802
So Acl is
ip access-list extended zoom
 permit udp any any eq 8801
 permit udp any any eq 8802
 deny   udp any any
Class map is
class-map match-any video
 match protocol h323
 match access-group name telemed
 match access-group name zoom
Policy is
  class video
  set dscp cs4
And I do assign the service-policy output to the needed port.
I am planning a reboot of the router when Time allows.
Thanks.
Philip D'Ath
Advisor
Advisor
If the configs are the same, and traffic is being marked correctly - is the problematic 2911 running the same IOS software version as a 2911 that is working?
Yes , Several 2911s, all running Ver 15.2.
And this one router was working for about a year with most of the current config on it.
Any changes were made to all of them. Like keeping things standard as much as I can.
Just didn't know if anyone had ran across something like this before.
Anyone interested, A simple restart of the router fixed this issue.
Recognize Your Peers
