Router with E1 Modules
avilt
Participant
Participant
I have Cisco 7200 series routers with E1 cards which are quite old. E1 cards are connected to ISP SDH network.
I need to replace the routers, can I still but E1 modules from Cisco? Please provide the suitable router model and E1 modules. Also any alternatives if I have to get rod of E1 modules?
balaji.bandi
Look at cisco 7200 router replacement
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/technical_references/7200_Migration_Doc.html
if you want to suggest E1 Modules, can you post show inventory or model of E1 Module you have
BB
apart from show inventory any other command to gather this details. The router is at remote location
based on the post you looking to replace the model with E1 card. so get inventory and modules information, so you can buy right module along with router to replace ( good old 7200).
if you looking to get more information, it is beneficial for you.
BB
