SA520 Remote Management
jeremygarman
I get the login screen for remote management, but get a "Blocked to Login From WAN side" when I try to login with the Administrator account.
5 Replies 5
jeremygarman
Remote management is turned on from any IP.
same problem with a SA540 (firmware 2.1.18) installed in DMZ of a Freebox
Vincent
Click the Administration Tab, Then Users and there is a setting to fix this in the user policies.
Thanks . You can mark this topic as solved ^^
adminex007
I also have a problem with access to SA520W from Internet.I`ve enabled remote management from All IP addresses. Remote port is set to 444.
But when I try to connect to device in my browser I have an error that remote host reset connection..
Is I also need to configure a rule in firewall?
Sorry for my bad English..
