SDM and a 2600 router
im-here-now
I am assuming the reason that SDM won't recognize SSH or Telnet user and/or passwords is becuase I am trying to connect SDM to a plain 2611, as opposed to a 2611XM? What's the difference between the two routers? I got SDM installed on a XP Home box (also tried an XP Pro), which it says it doesn't support, so I was hoping that those two little letters in the router version wouldn't be that much of a challenge. I guess it was. On a side note, SDM supports Windows ME, for pete's sake, and it doesn't officially support XP Home! What's up with that?
spremkumar
Level 9
Level 9
You can check out the differences between different 2600 models in the below mentioned link under Cisco 2600 Series System Specifications.
http://cisco.com/en/US/products/hw/routers/ps259/products_data_sheet0900aecd800fa5be.html
regds
