Searching archive by pattern in RME4 vs. 3.5
getwithrob
Level 3
Level 3
In the old version you could only search by 3 fields the new version has 10 search field which is great!
Question:In the old version, it would find the match(es) then pull the config up in a window so you could easily see where that string is located in the config.
See attachment. Am I missing something here?
Joe Clarke
The short answer is that this kind of highlight was doable because we used to use client-sided Java.
The long answer is that while doing the same kind of line highlighting would not be possible in 4.x, we should at least color-coding the line, or making it somewhat obvious where the matches are. You should pursue an enhancement request with your account team.
Joe Clarke
'Will do so sir.
