05-03-2023 01:33 AM
Hi everyone,
To all engineers who love cisco CLI, what is the possible solution to this below error
Key exchange failed.
No compatible MAC. The server supports these MACs: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha2-512
Any possible solution will be appreciated.
kind Regards,
Michael
05-03-2023 02:39 AM
01-18-2024 05:51 AM
Hi Amutua 17
I had the same problem on the 9000 Series Switches, I don't know exactly why it gives this error but I just upgraded SCRT to version 9.5 and the equipment already appeared in the command line.
Hope this helps.
05-03-2024 09:02 PM
Hi amutua17 and jonasmariquele19
Hi You will get these kind of errors in SecureCRT only not no Putty or teraterm try to login, In secureCRT you need to delete the ssh.ini file AppData\Roaming\VanDyke\Config and restart the SSH services
05-09-2024 04:36 AM
this didn't resolve the poblem.
