Highlighted
sendmail tcl eem policy not working
I'm having trouble to get the library smtp_send_email working.
I have a tcl script which I register with eem. I set all the env vars like _email_server, _email_to etc.
But when the script is executed i get the following message:
002716: Nov 25 2015 12:54:22.764 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_connect : attempt 1
002717: Nov 25 2015 12:54:23.023 CET: [fh_smtp_debug_cmd]
002718: Nov 25 2015 12:54:23.023 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_read  : 220 <mailservername> -- Server ESMTP (PMDF V6.6#32005)
002719: Nov 25 2015 12:54:23.023 CET: [fh_smtp_debug_cmd]
002720: Nov 25 2015 12:54:23.023 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_write : HELO es334A2.mydomain.de
002721: Nov 25 2015 12:54:23.089 CET: [fh_smtp_debug_cmd]
002722: Nov 25 2015 12:54:23.089 CET:
es334A2#%HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_read  : 250 <mailservername> OK, [172.19.17.196].
002723: Nov 25 2015 12:54:23.089 CET: [fh_smtp_debug_cmd]
002724: Nov 25 2015 12:54:23.089 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_write : MAIL FROM:<es334A2@mydomain.com>
002725: Nov 25 2015 12:54:23.170 CET: [fh_smtp_debug_cmd]
002726: Nov 25 2015 12:54:23.170 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_read  : 250 2.5.0 Address Ok.
002727: Nov 25 2015 12:54:23.170 CET: [fh_smtp_debug_cmd]
002728: Nov 25 2015 12:54:23.170 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_write : RCPT TO:<me@mydomain.com>
002729: Nov 25 2015 12:54:23.250 CET: [fh_smtp_debug_cmd]
002730: Nov 25 2015 12:54:23.250 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_read  : 250 2.1.5 me@mydomain.com OK.
002731: Nov 25 2015 12:54:23.250 CET: [fh_smtp_debug_cmd]
002732: Nov 25 2015 12:54:23.250 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_write : DATA
002733: Nov 25 2015 12:54:23.317 CET: [fh_smtp_debug_cmd]
002734: Nov 25 2015 12:54:23.317 CET: %HA_EM-6-LOG: vlanmap.tcl : DEBUG(smtp_lib) : smtp_read  : 354 Enter mail, end with a single ".".
002735: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl: list element in quotes followed by "." instead of space
002736: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:     while executing
002737: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl: "smtp_send_email $mail_msg"
002738: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:     invoked from within
002739: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl: "$slave eval $Contents"
002740: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:     (procedure "eval_script" line 7)
002741: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:     invoked from within
002742: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl: "eval_script slave $scriptname"
002743: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:     invoked from within
002744: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl: "if {$security_level == 1} {       #untrusted script
002745: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:      interp create -safe slave
002746: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:      interp share {} stdin slave
002747: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:      interp share {} stdout slave
002748: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl: ..."
002749: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl:     (file "tmpsys:/lib/tcl/base.tcl" line 50)
002750: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl: Tcl policy execute failed:
002751: Nov 25 2015 12:54:23.320 CET: %HA_EM-6-LOG: vlanmap.tcl: list element in quotes followed by "." instead of space
myswitch#
The Hardware is 2960X with IOS 15.2(4)E.
The event manager version is:
Embedded Event Manager Version 4.00
Component Versions:
eem: (rel9)1.2.6
eem-gold: (rel1)1.0.2
eem-call-home: (rel2)1.0.4
Event Detectors:
Name                Version   Node        Type
application         01.00     node0/0     RP
identity            01.00     node0/0     RP
mat                 01.00     node0/0     RP
neighbor-discovery  01.00     node0/0     RP
generic             01.00     node0/0     RP
routing             03.00     node0/0     RP
syslog              01.00     node0/0     RP
cli                 01.00     node0/0     RP
config              01.00     node0/0     RP
counter             01.00     node0/0     RP
crash               01.00     node0/0     RP
ds                  01.00     node0/0     RP
env                 01.00     node0/0     RP
gold                01.00     node0/0     RP
interface           01.00     node0/0     RP
ioswdsysmon         01.00     node0/0     RP
nf                  01.00     node0/0     RP
none                01.00     node0/0     RP
oir                 01.00     node0/0     RP
snmp                01.00     node0/0     RP
snmp-object         01.00     node0/0     RP
snmp-notification   01.00     node0/0     RP
test                01.00     node0/0     RP
timer               01.00     node0/0     RP
I don't understand the message: "list element in quotes followed by "." instead of space"
This is the code I use:
#smtp_send_email
if {$withmail == 1 } {
set mail_pre "Mailservername: <mailservername>\n"
append mail_pre "From: es334A2@mydomain.com\n"
append mail_pre "To: me@mydomain.com\n"
append mail_pre "Cc: \n"
append mail_pre "Subject: LINK UP\n"
append mail_pre " \n"
append mail_pre "Test1\n"
append mail_pre "Test2\n\n"
set mail_msg [uplevel #0 [list subst -nobackslashes -nocommands $mail_pre]]
puts stdout "mail_msg:\n$mail_msg"
puts stdout "routername: $routername"
if [catch {smtp_send_email $mail_msg} result] {
    error $result $errorInfo
Any help is very appreciated.
Kind regards,
Andreas
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Cisco Employee
Wrong split chars.  Try this:
proc ::cisco::lib::smtp_chk_reply { sock succ_code } {
  variable reply_code_str
  set r [ smtp_read $sock ]
  if {$r == -1} {
      return -code error "Socket closed by remote server"
  set k [lindex [split $r " "] 0]
  if {$k != $succ_code} {
      return -code error [concat From SMTP server: $r\n$reply_code_str($k)]
19 REPLIES 19
Highlighted
This code is not proper Tcl.  Please attach the script instead of pasting in the code so we can get a complete picture the way it is actually being interpreted.
Highlighted
Hello Joe,
thanks for working on my issue.Here is the script. I replaced the real servername/addresses etc...
I registered it with:
'event manager policy vlanmap.tcl type user'
Kind regards,
Andreas
Highlighted
I don't see anything wrong with this code or the SMTP library code.  I can only guess that there is something else in your actual policy that I'm not seeing.  But if all you do is replace the email addresses with the proper values and re-register the policy, then it should work.
Highlighted
yes, all I do is replace the values with real ones. But then it fails with the weird message:
"list element in quotes followed by "." instead of space". I don't understand if this is related to the "send_email-library" or the tcl syntax...
It doesn't matter what's in the mailbody. It seems that it doesn't came to step to process the mailbody...
The policy looks like this:
es334A2#sh event manager policy registered
No.  Class     Type    Event Type          Trap  Time Registered           Name
1    script    user    syslog              Off   Fri Nov 27 09:09:01 2015  vlanmap.tcl
 1: syslog: pattern {LINEPROTO-5-UPDOWN: Line protocol on Interface (.*), changed state to up}
 nice 0 queue-priority normal maxrun 300.000 scheduler rp_primary Secu none
Kind regards,
Andreas
Highlighted
While I don't have a 2960X, I tested with your script and the smtp_lib.tcl from the 15.2(4)E source code, and it works.
[smtp_connect] : attempt 1
[smtp_read ] : 220 xxx.cisco.com ESMTP FOO 1.2.3.4/5.6.7.8; Sun, 29 Nov 2015 17:47:59 GMT
[smtp_write] : HELO yyy.cisco.com
[smtp_read ] : 250 xxx.cisco.com Hello aaa.cisco.com [10.117.46.173], pleased to meet you
[smtp_write] : MAIL FROM:<jclarke@cisco.com>
[smtp_read ] : 250 2.1.0 <jclarke@cisco.com>... Sender ok
[smtp_write] : RCPT TO:<jclarke@cisco.com>
[smtp_read ] : 250 2.1.5 <jclarke@cisco.com>... Recipient ok
[smtp_write] : DATA
[smtp_read ] : 354 Enter mail, end with "." on a line by itself
[smtp_write] : Date: 29 Nov 2015 12:47:59 EST
[smtp_write] : Message-ID: <20151129124759.0@yyy.cisco.com>
[smtp_write] : From: jclarke@cisco.com
To: jclarke@cisco.com
Cc:
Subject: LINK UP
Testmessage if Link goes up
[smtp_write] : .
[smtp_read ] : 250 2.0.0 tATHlxxI002560 Message accepted for delivery
[smtp_write] : QUIT
[smtp_read ] : 221 2.0.0 xxx.cisco.com closing connection
So, I can only guess that the script you have registered with the EEM server is not what you've posted here.  Make sure that when you make changes you re-register the policy or the changes will not go into effect.
This error typically occurs when one has a '#' on a line thinking it's a comment.  Embedded comments must be preceded with a ';'.
Highlighted
Hello Joe,
the script I've registered ist exactly what I've posted.
But I made another trial.
I took a part of the original vlanmap.tcl(attached mail_test.tcl). And registered it(I know that I have to re-register the script each time I make changes to the script.).
I get a similar error message(log is attached).
I reloaded the machine twice.
To me it looks like that the lib or anything else in EEM/tcl is broken.
Edit:
I just testet the same script on a WS-C4500X-16 with IOS "cat4500e-universalk9.SPA.03.08.00.E.152-4.E.bin" and it gives me the same error message ?!? I Don't know what I'm doing wrong...
Kind regards,
Andreas
Highlighted
It might be time to open a case with TAC, then.  There may be different code on the 2960X that I am not seeing when I pull it from the source code.
Highlighted
Ok, I'll see if I can address this to the TAC.
Curious that the same message appears on the 4500X...
Kind regards,
Andreas
Highlighted
Presumably with the TAC case you can share the actual script.  There still might be something in your script that is being hidden here.  I certainly connect reproduce, and I haven't seen anyone report this problem before.
Highlighted
I opened a ticket and I provide the script I attached here.
I'm wondering that you assume that there is something hidden... the script I attached here is definitely the one on the switch.
Kind regards,
Andreas
Highlighted
I got answer from the "TAC":
EEM scripts no longer supported by TAC, and it is only supported by support forums.
Please continue to check with Cisco Support Community.
>>https://supportforums.cisco.com/discussion/12714071/sendmail-tcl-eem-policy-not-working
Rgds,
Andreas
Highlighted
What is the SR number?
Highlighted
SR 637393499
Rgds,
Andreas
Highlighted
Hi Joe,
any news on this?
Rgds,
Andreas
Content for Community-Ad
