Cisco Community Designated VIP Class of 2020
552
Beginner
Set CPU threshold value for generating TRAP.
I have cisco cat6509 switches running IOS 12.2(18)SXF11. I want to configure the threshold for CPU utilization for the device to generate traps.
I tried using the command "process cpu threshold type total rising <threshold> <interval> ... but this command doesn't seem to be available in this version.
1 REPLY 1
Highlighted
Collaborator
Re: Set CPU threshold value for generating TRAP.
That particular command appears to be introduced in 12.3T.
Since EEM 2.1 is available on IOS 12.2(18)SXF11, you can take the EEM alternative, in particular the example posted by "anonymous" but adapt it to generate SNMP trap rather than disable wccp.
http://blog.ioshints.info/2008/06/generate-snmp-trap-on-high-cpu-load.html
Content for Community-Ad
July's Community Spotlight Awards
