Setting IE-1000 port bitrate
esarearthur
I will like someone to share with me how to change the port speed on an IE-1000 using the web GUI. I will like to know if this is possible since I don't see it anywhere on the product specs on how to do it.
@esarearthur
 It this because you dont have access on the CLI?  I am not sure this is possible using the web interface but using CLI is one command.
Thanks for the feedback, Can you share the command for CLI. I am yet to buy the IE-1000 so don't know if there is CLI.
@esarearthur
 Your are welcome but for my surprise, this device actually does not support CLI
https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie1000/release_notes/b_ie1k_1-7rn.html
"Web GUI interface only
Through a user-friendly web device manager, the Cisco IE 1000 provides easy out-of-the-box configuration and simplified operational manageability to deliver advanced and secure industrial networks."
When you get your device you can return and we can find what you need.
