SF300 memory and ports statistics OIDs
I am trying to retrieve raw data from my SF300 switches using traps and OIDs, as not all information can be found in log buffer. However, I am not able to find OIDs reflecting system memory usage and critical information regarding ports statistics, such as bandwidth consumption and errors rate.
Thanks in advance for all your help.
balaji.bandi
Thanks a lot for the response, I have found some useful information. However, memory OID seems not the be same which is not very helpful to find which OID is providing accurate memory consumption rate (knowing that SF300 do not have show memory command).
- Below links are no longer visible :
Memory statistics via CISCO-ENHANCED-MEMPOOL-MIB and CISCO-MEMORY-POOL-MIB
- And the Memory Mib mentioned here https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/15216-contiguous-memory.html, do not exist on the sf300 I am working on :
.1.3.6.1.4.1.9.9.48. do not exist and values starts to show up at .49
Thanks in advance.
