11-12-2020 09:30 PM
Hi all
Having this issue for a while now, but desperate to get it working. Its a super simple setup
1 x SG-350-10P switch
VLAN 1 (default) - 192.168.1.254/24
VLAN 2 (Nodes) - 192.168.2.254/24
VLAN 3 (clients) - 192.168.3.254/24
I have setup port GE2 as access on VLAN2
I have setup port GE3 as access on VLAN3
SBC ARM pc on VLAN2 - static IP of 192.168.2.11/24 - gateway 192.168.2.254
Windows PC on VLAN3 - static IP of 192.168.3.11/24 - gateway 192.168.3.254
IPV4 routing is enabled but I cannot ping from the windows PC to the ARM device.....I've read that the SG-350 comes as L3 out of the box, however I just cannot get this setup to work. Routes aren't being auto generated like I've seen elsewhere so I assume the routing function is just dropping packets at the gateway
11-12-2020 09:30 PM
Adding in that I also cannot ping the other way**
11-13-2020 12:33 AM
Hi there,
Can you share the running config of the switch, along with the output of:
sh ip route
sh ip arp
sh mac address
Also can the two PCs ping their respective gateway addresses? With regard to the windows PC, have you either disabled with windows firewall are configure a permit rule to respond to ICMP?
cheers,
Seb.
11-13-2020 09:38 AM
It might be helpful to see the arp table from each of the PCs. Can the SG350 ping to the PCs?
11-15-2020 04:40 PM
Arp tables from each PC:
PC1
Interface: 192.168.1.11 --- 0xe
Internet Address Physical Address Type
192.168.1.254 70-0b-4f-65-b5-94 dynamic
192.168.1.255 ff-ff-ff-ff-ff-ff static
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
239.255.255.250 01-00-5e-7f-ff-fa static
255.255.255.255 ff-ff-ff-ff-ff-ff static
PC 2
Interface: 192.168.2.10 --- 0xe
192.168.2.254 70-0b-4f-65-b5-94 dynamic
192.168.2.255 ff-ff-ff-ff-ff-ff static
239.255.255.251 01-00-5e-7f-ff-fb static
11-15-2020 04:41 PM
Each PC can ping the switch at their respective vlan addresses and vice versa
just can't ping across vlans
11-17-2020 08:45 AM
Thanks for posting the outputs and for the switch config. The switch config does match up with your description of having 3 vlans with hosts connected in 2 of the vlans. And the PC arp tables reflect that. I understand that the PC at 192.168.1.11 can ping its gateway at 192.168.1.254. Can that PC ping the 192.168.2.254 switch address?
There are a couple of things that I wonder about:
- the config shows a DHCP pool configured for vlan 1. But the vlan 1 interface config seems to disable DHCP. Is this intended?
- some of the outputs from the switch do not match the config
switch65b594#sh ip route
is clear that IP forwarding is enabled. But it shows only vlan 1 and vlan 2 and the addresses shown do not match what is in the config.
switch65b594#show arp
also shows only vlan 1 and vlan 2
- I am a bit surprised that it seems that the switch uses the same mac address for interfaces vlan 1 and vlan 2 of 70-0b-4f-65-b5-94. I don't know that it is a problem, but it is a surprise.
11-15-2020 04:39 PM
and
I have the vlan switch address set as the gateway for each respective vlan (192.168.1.254, 192.168.2.254, 192.168.3.254) and the PC's can ping and receive pings from these addresses in each respective VLAN
I'm now using a windows PC as both devices for simplicities sake. Both firewalls completely off so no ICMP requests are being blocked
Maximum Parallel Paths: 1 (1 after reset)
Total number of entries: 2
VLAN Interface IP address HW address status
vlan 1 gi10 192.168.1.11 7c:8b:ca:11:f5:2c dynamic
vlan 2 gi2 192.168.2.10 00:e0:4c:68:01:59 dynamic
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
C 192.168.1.0/24 is directly connected, vlan 1
C 192.168.2.0/24 is directly connected, vlan 2
switch65b594#show mac address
Flags: I - Internal usage VLAN
Aging time is 300 sec
Vlan Mac Address Port Type
1 70:0b:4f:65:b5:94 0 self
1 7c:8b:ca:11:f5:2c gi10 dynamic
2 00:e0:4c:68:01:59 gi2 dynamic
switch65b594#
switch65b594#sh running-config
config-file-header
switch65b594
v2.3.5.63 / RLINUX_923_093
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
vlan database
vlan 2-3
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp pool network vlan1dhcp
address low 192.168.1.10 high 192.168.1.30 255.255.255.0
default-router 192.168.1.254
exit
ip dhcp pool network vlan2dhcp
address low 192.168.2.10 high 192.168.2.30 255.255.255.0
default-router 192.168.2.254
exit
ip dhcp pool network vlan3dhcp
address low 192.168.3.10 high 192.168.3.30 255.255.255.0
default-router 192.168.3.254
exit
bonjour interface range vlan 1
hostname switch65b594
username cisco password encrypted 041210e66a84cf9701ae3c11bc267e5936fbb127 privilege 15
ip ssh server
interface vlan 1
ip address 192.168.1.254 255.255.255.0
no ip address dhcp
interface vlan 2
name anchors
ip address 192.168.2.254 255.255.255.0
interface vlan 3
name clients
ip address 192.168.3.254 255.255.255.0
interface GigabitEthernet2
switchport access vlan 2
interface GigabitEthernet3
switchport access vlan 3
exit
