SG350-24 24P gigabit PoE switch
Okami11
I would like t know if in this type of switch one can connect any type of Devices regardless they are powered or not. Is it safe to use in powered devices like a PC or a laptop. ? does the switch is aware of this automatically or each port ican be programed by the Admin to provide or not power to the device ? thanks for your responses.
balaji.bandi
it automatic, so you not required to do anything. it automatically detect PoE device and supply required Power.
if you connect Pc it work as expected.
you can also disable if you do not like any of the port not to provide PoE Power.(can be disable)
BB
balaji.bandi
BB
Thank you for your prompt answer. You have been very helpful.
