Okami11
Beginner
SG350-24 24P gigabit PoE switch
I would like t know if in this type of switch one can connect any type of Devices regardless they are powered or not. Is it safe to use in powered devices like a PC or a laptop. ? does the switch is aware of this automatically or each port ican be programed by the Admin to provide or not power to the device ? thanks for your responses.
1 ACCEPTED SOLUTION
balaji.bandi
VIP Master
it automatic, so you not required to do anything. it automatically detect PoE device and supply required Power.
if you connect Pc it work as expected.
you can also disable if you do not like any of the port not to provide PoE Power.(can be disable)
BB
How to Ask The Community for Help
2 REPLIES 2
balaji.bandi
VIP Master
BB
Thank you for your prompt answer. You have been very helpful.
