10-05-2010 07:17 PM
I have downloaded these 2 Tcl scripts from this previous discussion and from the sounds of it it's exactly what I've been looking for. But the problem is I'm new to EEM and have no idea how to go about putting these on the switches themselves. I've searched for configuration guides but to no prevail. Any help is greatly appreciated. Here's the link to previous discussion:
https://supportforums.cisco.com/thread/164684.pdf;jsessionid=EEEEE143342DAAB34706D608D5C4C920.node0
10-15-2010 04:47 AM
I'll post tonights output when the script runs again.
10-15-2010 07:04 AM
The debug output was the same as last night. Here's the show even man hist event:
No. Job Id Status Time of Event Event Type Name
1 1981 success Fri Oct15 18:06:28 2010 syslog script: sl_suspend_ports.tcl
2 1982 success Fri Oct15 19:07:50 2010 syslog script: sl_suspend_ports.tcl
3 1983 success Fri Oct15 19:07:52 2010 syslog script: sl_suspend_ports.tcl
4 1984 success Fri Oct15 19:27:40 2010 syslog script: sl_suspend_ports.tcl
5 1985 success Fri Oct15 19:27:41 2010 syslog script: sl_suspend_ports.tcl
6 1986 success Fri Oct15 19:28:17 2010 syslog script: sl_suspend_ports.tcl
7 1987 success Fri Oct15 19:28:47 2010 syslog script: sl_suspend_ports.tcl
8 1988 success Fri Oct15 19:44:59 2010 syslog script: sl_suspend_ports.tcl
9 1989 success Fri Oct15 19:45:01 2010 syslog script: sl_suspend_ports.tcl
10 1990 success Sat Oct16 00:00:00 2010 timer cron script: tm_suspend_ports.tcl
Still didn't disable the ports. I've attached the susp_ports.dat again.
10-15-2010 07:56 AM
10-15-2010 03:26 PM
Here's the output from running the script. Below that is the log file.
XXX: Looking at iface FastEthernet1/0/1
XXX: line 'FastEthernet1/0/1 unassigned YES unset up up' is up
XXX: FastEthernet1/0/1 not found in array
XXX: Looking at iface FastEthernet1/0/2
XXX: line 'FastEthernet1/0/2 unassigned YES unset up up' is up
XXX: FastEthernet1/0/2 not found in array
XXX: Looking at iface FastEthernet1/0/3
XXX: line 'FastEthernet1/0/3 unassigned YES unset down down' is down
XXX: FastEthernet1/0/3 not found in array
XXX: Adding FastEthernet1/0/3 to ports array
XXX: Looking at iface FastEthernet1/0/4
XXX: line 'FastEthernet1/0/4 unassigned YES unset up up' is up
XXX: FastEthernet1/0/4 not found in array
XXX: Looking at iface FastEthernet1/0/5
XXX: line 'FastEthernet1/0/5 unassigned YES unset up up' is up
XXX: FastEthernet1/0/5 not found in array
XXX: Looking at iface FastEthernet1/0/6
XXX: line 'FastEthernet1/0/6 unassigned YES unset down down' is down
XXX: FastEthernet1/0/6 not found in array
XXX: Adding FastEthernet1/0/6 to ports array
XXX: Looking at iface FastEthernet1/0/7
XXX: line 'FastEthernet1/0/7 unassigned YES unset up up' is up
XXX: FastEthernet1/0/7 not found in array
XXX: Looking at iface FastEthernet1/0/8
XXX: line 'FastEthernet1/0/8 unassigned YES unset up up' is up
XXX: FastEthernet1/0/8 not found in array
XXX: Looking at iface FastEthernet1/0/9
XXX: line 'FastEthernet1/0/9 unassigned YES unset up up' is up
XXX: FastEthernet1/0/9 not found in array
XXX: Looking at iface FastEthernet1/0/10
XXX: line 'FastEthernet1/0/10 unassigned YES unset up up' is up
XXX: FastEthernet1/0/10 not found in array
XXX: Looking at iface FastEthernet1/0/11
XXX: line 'FastEthernet1/0/11 unassigned YES unset up up' is up
XXX: FastEthernet1/0/11 not found in array
XXX: Looking at iface FastEthernet1/0/12
XXX: line 'FastEthernet1/0/12 unassigned YES unset down down' is down
XXX: FastEthernet1/0/12 not found in array
XXX: Adding FastEthernet1/0/12 to ports array
XXX: Looking at iface FastEthernet1/0/13
XXX: line 'FastEthernet1/0/13 unassigned YES unset down down' is down
XXX: FastEthernet1/0/13 not found in array
XXX: Adding FastEthernet1/0/13 to ports array
XXX: Looking at iface FastEthernet1/0/14
XXX: line 'FastEthernet1/0/14 unassigned YES unset up up' is up
XXX: FastEthernet1/0/14 not found in array
XXX: Looking at iface FastEthernet1/0/15
XXX: line 'FastEthernet1/0/15 unassigned YES unset up up' is up
XXX: FastEthernet1/0/15 not found in array
XXX: Looking at iface FastEthernet1/0/16
XXX: line 'FastEthernet1/0/16 unassigned YES unset up up' is up
XXX: FastEthernet1/0/16 not found in array
XXX: Looking at iface FastEthernet1/0/17
XXX: line 'FastEthernet1/0/17 unassigned YES unset up up' is up
XXX: FastEthernet1/0/17 not found in array
XXX: Looking at iface FastEthernet1/0/18
XXX: line 'FastEthernet1/0/18 unassigned YES unset up up' is up
XXX: FastEthernet1/0/18 not found in array
XXX: Looking at iface FastEthernet1/0/19
XXX: line 'FastEthernet1/0/19 unassigned YES unset down down' is down
XXX: FastEthernet1/0/19 not found in array
XXX: Adding FastEthernet1/0/19 to ports array
XXX: Looking at iface FastEthernet1/0/20
XXX: line 'FastEthernet1/0/20 unassigned YES unset down down' is down
XXX: FastEthernet1/0/20 not found in array
XXX: Adding FastEthernet1/0/20 to ports array
XXX: Looking at iface FastEthernet1/0/21
XXX: line 'FastEthernet1/0/21 unassigned YES unset down down' is down
XXX: FastEthernet1/0/21 not found in array
XXX: Adding FastEthernet1/0/21 to ports array
XXX: Looking at iface FastEthernet1/0/22
XXX: line 'FastEthernet1/0/22 unassigned YES unset up up' is up
XXX: FastEthernet1/0/22 not found in array
XXX: Looking at iface FastEthernet1/0/23
XXX: line 'FastEthernet1/0/23 unassigned YES unset down down' is down
XXX: FastEthernet1/0/23 not found in array
XXX: Adding FastEthernet1/0/23 to ports array
XXX: Looking at iface FastEthernet1/0/24
XXX: line 'FastEthernet1/0/24 unassigned YES unset down down' is down
XXX: FastEthernet1/0/24 not found in array
XXX: Adding FastEthernet1/0/24 to ports array
XXX: Looking at iface FastEthernet1/0/25
XXX: line 'FastEthernet1/0/25 unassigned YES unset down down' is down
XXX: FastEthernet1/0/25 not found in array
XXX: Adding FastEthernet1/0/25 to ports array
XXX: Looking at iface FastEthernet1/0/26
XXX: line 'FastEthernet1/0/26 unassigned YES unset up up' is up
XXX: FastEthernet1/0/26 not found in array
XXX: Looking at iface FastEthernet1/0/27
XXX: line 'FastEthernet1/0/27 unassigned YES unset up up' is up
XXX: FastEthernet1/0/27 not found in array
XXX: Looking at iface FastEthernet1/0/28
XXX: line 'FastEthernet1/0/28 unassigned YES unset up up' is up
XXX: FastEthernet1/0/28 not found in array
XXX: Looking at iface FastEthernet1/0/29
XXX: line 'FastEthernet1/0/29 unassigned YES unset down down' is down
XXX: FastEthernet1/0/29 not found in array
XXX: Adding FastEthernet1/0/29 to ports array
XXX: Looking at iface FastEthernet1/0/30
XXX: line 'FastEthernet1/0/30 unassigned YES unset down down' is down
XXX: FastEthernet1/0/30 not found in array
XXX: Adding FastEthernet1/0/30 to ports array
XXX: Looking at iface FastEthernet1/0/31
XXX: line 'FastEthernet1/0/31 unassigned YES unset down down' is down
XXX: FastEthernet1/0/31 not found in array
XXX: Adding FastEthernet1/0/31 to ports array
XXX: Looking at iface FastEthernet1/0/32
XXX: line 'FastEthernet1/0/32 unassigned YES unset down down' is down
XXX: FastEthernet1/0/32 not found in array
XXX: Adding FastEthernet1/0/32 to ports array
XXX: Looking at iface FastEthernet1/0/33
XXX: line 'FastEthernet1/0/33 unassigned YES unset up up' is up
XXX: FastEthernet1/0/33 not found in array
XXX: Looking at iface FastEthernet1/0/34
XXX: line 'FastEthernet1/0/34 unassigned YES unset up up' is up
XXX: FastEthernet1/0/34 not found in array
XXX: Looking at iface FastEthernet1/0/35
XXX: line 'FastEthernet1/0/35 unassigned YES unset up up' is up
XXX: FastEthernet1/0/35 not found in array
XXX: Looking at iface FastEthernet1/0/36
XXX: line 'FastEthernet1/0/36 unassigned YES unset down down' is down
XXX: FastEthernet1/0/36 not found in array
XXX: Adding FastEthernet1/0/36 to ports array
XXX: Looking at iface FastEthernet1/0/37
XXX: line 'FastEthernet1/0/37 unassigned YES unset up up' is up
XXX: FastEthernet1/0/37 not found in array
XXX: Looking at iface FastEthernet1/0/38
XXX: line 'FastEthernet1/0/38 unassigned YES unset down down' is down
XXX: FastEthernet1/0/38 not found in array
XXX: Adding FastEthernet1/0/38 to ports array
XXX: Looking at iface FastEthernet1/0/39
XXX: line 'FastEthernet1/0/39 unassigned YES unset down down' is down
XXX: FastEthernet1/0/39 not found in array
XXX: Adding FastEthernet1/0/39 to ports array
XXX: Looking at iface FastEthernet1/0/40
XXX: line 'FastEthernet1/0/40 unassigned YES unset down down' is down
XXX: FastEthernet1/0/40 not found in array
XXX: Adding FastEthernet1/0/40 to ports array
XXX: Looking at iface FastEthernet1/0/41
XXX: line 'FastEthernet1/0/41 unassigned YES unset up up' is up
XXX: FastEthernet1/0/41 not found in array
XXX: Looking at iface FastEthernet1/0/42
XXX: line 'FastEthernet1/0/42 unassigned YES unset down down' is down
XXX: FastEthernet1/0/42 not found in array
XXX: Adding FastEthernet1/0/42 to ports array
XXX: Looking at iface FastEthernet1/0/43
XXX: line 'FastEthernet1/0/43 unassigned YES unset down down' is down
XXX: FastEthernet1/0/43 not found in array
XXX: Adding FastEthernet1/0/43 to ports array
XXX: Looking at iface FastEthernet1/0/44
XXX: line 'FastEthernet1/0/44 unassigned YES unset up up' is up
XXX: FastEthernet1/0/44 not found in array
XXX: Looking at iface FastEthernet1/0/45
XXX: line 'FastEthernet1/0/45 unassigned YES unset up up' is up
XXX: FastEthernet1/0/45 not found in array
XXX: Looking at iface FastEthernet1/0/46
XXX: line 'FastEthernet1/0/46 unassigned YES unset down down' is down
XXX: FastEthernet1/0/46 not found in array
XXX: Adding FastEthernet1/0/46 to ports array
XXX: Looking at iface FastEthernet1/0/47
XXX: line 'FastEthernet1/0/47 unassigned YES unset up up' is up
XXX: FastEthernet1/0/47 not found in array
XXX: Looking at iface FastEthernet1/0/48
XXX: line 'FastEthernet1/0/48 unassigned YES unset down down' is down
XXX: FastEthernet1/0/48 not found in array
XXX: Adding FastEthernet1/0/48 to ports array
XXX: Looking at iface GigabitEthernet1/0/1
XXX: line 'GigabitEthernet1/0/1 unassigned YES unset up up' is up
XXX: GigabitEthernet1/0/1 not found in array
XXX: Looking at iface GigabitEthernet1/0/2
XXX: line 'GigabitEthernet1/0/2 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet1/0/2 not found in array
XXX: Looking at iface GigabitEthernet1/0/3
XXX: line 'GigabitEthernet1/0/3 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet1/0/3 not found in array
XXX: Looking at iface GigabitEthernet1/0/4
XXX: line 'GigabitEthernet1/0/4 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet1/0/4 not found in array
XXX: Looking at iface FastEthernet2/0/1
XXX: line 'FastEthernet2/0/1 unassigned YES unset down down' is down
XXX: FastEthernet2/0/1 not found in array
XXX: Adding FastEthernet2/0/1 to ports array
XXX: Looking at iface FastEthernet2/0/2
XXX: line 'FastEthernet2/0/2 unassigned YES unset down down' is down
XXX: FastEthernet2/0/2 not found in array
XXX: Adding FastEthernet2/0/2 to ports array
XXX: Looking at iface FastEthernet2/0/3
XXX: line 'FastEthernet2/0/3 unassigned YES unset down down' is down
XXX: FastEthernet2/0/3 not found in array
XXX: Adding FastEthernet2/0/3 to ports array
XXX: Looking at iface FastEthernet2/0/4
XXX: line 'FastEthernet2/0/4 unassigned YES unset down down' is down
XXX: FastEthernet2/0/4 not found in array
XXX: Adding FastEthernet2/0/4 to ports array
XXX: Looking at iface FastEthernet2/0/5
XXX: line 'FastEthernet2/0/5 unassigned YES unset down down' is down
XXX: FastEthernet2/0/5 not found in array
XXX: Adding FastEthernet2/0/5 to ports array
XXX: Looking at iface FastEthernet2/0/6
XXX: line 'FastEthernet2/0/6 unassigned YES unset down down' is down
XXX: FastEthernet2/0/6 not found in array
XXX: Adding FastEthernet2/0/6 to ports array
XXX: Looking at iface FastEthernet2/0/7
XXX: line 'FastEthernet2/0/7 unassigned YES unset down down' is down
XXX: FastEthernet2/0/7 not found in array
XXX: Adding FastEthernet2/0/7 to ports array
XXX: Looking at iface FastEthernet2/0/8
XXX: line 'FastEthernet2/0/8 unassigned YES unset down down' is down
XXX: FastEthernet2/0/8 not found in array
XXX: Adding FastEthernet2/0/8 to ports array
XXX: Looking at iface FastEthernet2/0/9
XXX: line 'FastEthernet2/0/9 unassigned YES unset up up' is up
XXX: FastEthernet2/0/9 not found in array
XXX: Looking at iface FastEthernet2/0/10
XXX: line 'FastEthernet2/0/10 unassigned YES unset down down' is down
XXX: FastEthernet2/0/10 not found in array
XXX: Adding FastEthernet2/0/10 to ports array
XXX: Looking at iface FastEthernet2/0/11
XXX: line 'FastEthernet2/0/11 unassigned YES unset down down' is down
XXX: FastEthernet2/0/11 not found in array
XXX: Adding FastEthernet2/0/11 to ports array
XXX: Looking at iface FastEthernet2/0/12
XXX: line 'FastEthernet2/0/12 unassigned YES unset down down' is down
XXX: FastEthernet2/0/12 not found in array
XXX: Adding FastEthernet2/0/12 to ports array
XXX: Looking at iface FastEthernet2/0/13
XXX: line 'FastEthernet2/0/13 unassigned YES unset down down' is down
XXX: FastEthernet2/0/13 not found in array
XXX: Adding FastEthernet2/0/13 to ports array
XXX: Looking at iface FastEthernet2/0/14
XXX: line 'FastEthernet2/0/14 unassigned YES unset down down' is down
XXX: FastEthernet2/0/14 not found in array
XXX: Adding FastEthernet2/0/14 to ports array
XXX: Looking at iface FastEthernet2/0/15
XXX: line 'FastEthernet2/0/15 unassigned YES unset down down' is down
XXX: FastEthernet2/0/15 not found in array
XXX: Adding FastEthernet2/0/15 to ports array
XXX: Looking at iface FastEthernet2/0/16
XXX: line 'FastEthernet2/0/16 unassigned YES unset down down' is down
XXX: FastEthernet2/0/16 not found in array
XXX: Adding FastEthernet2/0/16 to ports array
XXX: Looking at iface FastEthernet2/0/17
XXX: line 'FastEthernet2/0/17 unassigned YES unset down down' is down
XXX: FastEthernet2/0/17 not found in array
XXX: Adding FastEthernet2/0/17 to ports array
XXX: Looking at iface FastEthernet2/0/18
XXX: line 'FastEthernet2/0/18 unassigned YES unset down down' is down
XXX: FastEthernet2/0/18 not found in array
XXX: Adding FastEthernet2/0/18 to ports array
XXX: Looking at iface FastEthernet2/0/19
XXX: line 'FastEthernet2/0/19 unassigned YES unset up up' is up
XXX: FastEthernet2/0/19 not found in array
XXX: Looking at iface FastEthernet2/0/20
XXX: line 'FastEthernet2/0/20 unassigned YES unset down down' is down
XXX: FastEthernet2/0/20 not found in array
XXX: Adding FastEthernet2/0/20 to ports array
XXX: Looking at iface FastEthernet2/0/21
XXX: line 'FastEthernet2/0/21 unassigned YES unset down down' is down
XXX: FastEthernet2/0/21 not found in array
XXX: Adding FastEthernet2/0/21 to ports array
XXX: Looking at iface FastEthernet2/0/22
XXX: line 'FastEthernet2/0/22 unassigned YES unset down down' is down
XXX: FastEthernet2/0/22 not found in array
XXX: Adding FastEthernet2/0/22 to ports array
XXX: Looking at iface FastEthernet2/0/23
XXX: line 'FastEthernet2/0/23 unassigned YES unset down down' is down
XXX: FastEthernet2/0/23 not found in array
XXX: Adding FastEthernet2/0/23 to ports array
XXX: Looking at iface FastEthernet2/0/24
XXX: line 'FastEthernet2/0/24 unassigned YES unset up up' is up
XXX: FastEthernet2/0/24 not found in array
XXX: Looking at iface FastEthernet2/0/25
XXX: line 'FastEthernet2/0/25 unassigned YES unset down down' is down
XXX: FastEthernet2/0/25 not found in array
XXX: Adding FastEthernet2/0/25 to ports array
XXX: Looking at iface FastEthernet2/0/26
XXX: line 'FastEthernet2/0/26 unassigned YES unset down down' is down
XXX: FastEthernet2/0/26 not found in array
XXX: Adding FastEthernet2/0/26 to ports array
XXX: Looking at iface FastEthernet2/0/27
XXX: line 'FastEthernet2/0/27 unassigned YES unset down down' is down
XXX: FastEthernet2/0/27 not found in array
XXX: Adding FastEthernet2/0/27 to ports array
XXX: Looking at iface FastEthernet2/0/28
XXX: line 'FastEthernet2/0/28 unassigned YES unset down down' is down
XXX: FastEthernet2/0/28 not found in array
XXX: Adding FastEthernet2/0/28 to ports array
XXX: Looking at iface FastEthernet2/0/29
XXX: line 'FastEthernet2/0/29 unassigned YES unset down down' is down
XXX: FastEthernet2/0/29 not found in array
XXX: Adding FastEthernet2/0/29 to ports array
XXX: Looking at iface FastEthernet2/0/30
XXX: line 'FastEthernet2/0/30 unassigned YES unset down down' is down
XXX: FastEthernet2/0/30 not found in array
XXX: Adding FastEthernet2/0/30 to ports array
XXX: Looking at iface FastEthernet2/0/31
XXX: line 'FastEthernet2/0/31 unassigned YES unset down down' is down
XXX: FastEthernet2/0/31 not found in array
XXX: Adding FastEthernet2/0/31 to ports array
XXX: Looking at iface FastEthernet2/0/32
XXX: line 'FastEthernet2/0/32 unassigned YES unset up up' is up
XXX: FastEthernet2/0/32 not found in array
XXX: Looking at iface FastEthernet2/0/33
XXX: line 'FastEthernet2/0/33 unassigned YES unset down down' is down
XXX: FastEthernet2/0/33 not found in array
XXX: Adding FastEthernet2/0/33 to ports array
XXX: Looking at iface FastEthernet2/0/34
XXX: line 'FastEthernet2/0/34 unassigned YES unset down down' is down
XXX: FastEthernet2/0/34 not found in array
XXX: Adding FastEthernet2/0/34 to ports array
XXX: Looking at iface FastEthernet2/0/35
XXX: line 'FastEthernet2/0/35 unassigned YES unset down down' is down
XXX: FastEthernet2/0/35 not found in array
XXX: Adding FastEthernet2/0/35 to ports array
XXX: Looking at iface FastEthernet2/0/36
XXX: line 'FastEthernet2/0/36 unassigned YES unset down down' is down
XXX: FastEthernet2/0/36 not found in array
XXX: Adding FastEthernet2/0/36 to ports array
XXX: Looking at iface FastEthernet2/0/37
XXX: line 'FastEthernet2/0/37 unassigned YES unset down down' is down
XXX: FastEthernet2/0/37 not found in array
XXX: Adding FastEthernet2/0/37 to ports array
XXX: Looking at iface FastEthernet2/0/38
XXX: line 'FastEthernet2/0/38 unassigned YES unset down down' is down
XXX: FastEthernet2/0/38 not found in array
XXX: Adding FastEthernet2/0/38 to ports array
XXX: Looking at iface FastEthernet2/0/39
XXX: line 'FastEthernet2/0/39 unassigned YES unset up up' is up
XXX: FastEthernet2/0/39 not found in array
XXX: Looking at iface FastEthernet2/0/40
XXX: line 'FastEthernet2/0/40 unassigned YES unset up up' is up
XXX: FastEthernet2/0/40 not found in array
XXX: Looking at iface FastEthernet2/0/41
XXX: line 'FastEthernet2/0/41 unassigned YES unset down down' is down
XXX: FastEthernet2/0/41 not found in array
XXX: Adding FastEthernet2/0/41 to ports array
XXX: Looking at iface FastEthernet2/0/42
XXX: line 'FastEthernet2/0/42 unassigned YES unset down down' is down
XXX: FastEthernet2/0/42 not found in array
XXX: Adding FastEthernet2/0/42 to ports array
XXX: Looking at iface FastEthernet2/0/43
XXX: line 'FastEthernet2/0/43 unassigned YES unset down down' is down
XXX: FastEthernet2/0/43 not found in array
XXX: Adding FastEthernet2/0/43 to ports array
XXX: Looking at iface FastEthernet2/0/44
XXX: line 'FastEthernet2/0/44 unassigned YES unset down down' is down
XXX: FastEthernet2/0/44 not found in array
XXX: Adding FastEthernet2/0/44 to ports array
XXX: Looking at iface FastEthernet2/0/45
XXX: line 'FastEthernet2/0/45 unassigned YES unset up up' is up
XXX: FastEthernet2/0/45 not found in array
XXX: Looking at iface FastEthernet2/0/46
XXX: line 'FastEthernet2/0/46 unassigned YES unset up up' is up
XXX: FastEthernet2/0/46 not found in array
XXX: Looking at iface FastEthernet2/0/47
XXX: line 'FastEthernet2/0/47 unassigned YES unset up up' is up
XXX: FastEthernet2/0/47 not found in array
XXX: Looking at iface FastEthernet2/0/48
XXX: line 'FastEthernet2/0/48 unassigned YES unset up up' is up
XXX: FastEthernet2/0/48 not found in array
XXX: Looking at iface GigabitEthernet2/0/1
XXX: line 'GigabitEthernet2/0/1 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet2/0/1 not found in array
XXX: Looking at iface GigabitEthernet2/0/2
XXX: line 'GigabitEthernet2/0/2 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet2/0/2 not found in array
XXX: Looking at iface GigabitEthernet2/0/3
XXX: line 'GigabitEthernet2/0/3 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet2/0/3 not found in array
XXX: Looking at iface GigabitEthernet2/0/4
XXX: line 'GigabitEthernet2/0/4 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet2/0/4 not found in array
XXX: Looking at iface FastEthernet3/0/1
XXX: line 'FastEthernet3/0/1 unassigned YES unset up up' is up
XXX: FastEthernet3/0/1 not found in array
XXX: Looking at iface FastEthernet3/0/2
XXX: line 'FastEthernet3/0/2 unassigned YES unset down down' is down
XXX: FastEthernet3/0/2 not found in array
XXX: Adding FastEthernet3/0/2 to ports array
XXX: Looking at iface FastEthernet3/0/3
XXX: line 'FastEthernet3/0/3 unassigned YES unset up up' is up
XXX: FastEthernet3/0/3 not found in array
XXX: Looking at iface FastEthernet3/0/4
XXX: line 'FastEthernet3/0/4 unassigned YES unset down down' is down
XXX: FastEthernet3/0/4 not found in array
XXX: Adding FastEthernet3/0/4 to ports array
XXX: Looking at iface FastEthernet3/0/5
XXX: line 'FastEthernet3/0/5 unassigned YES unset up up' is up
XXX: FastEthernet3/0/5 not found in array
XXX: Looking at iface FastEthernet3/0/6
XXX: line 'FastEthernet3/0/6 unassigned YES unset up up' is up
XXX: FastEthernet3/0/6 not found in array
XXX: Looking at iface FastEthernet3/0/7
XXX: line 'FastEthernet3/0/7 unassigned YES unset up up' is up
XXX: FastEthernet3/0/7 not found in array
XXX: Looking at iface FastEthernet3/0/8
XXX: line 'FastEthernet3/0/8 unassigned YES unset up up' is up
XXX: FastEthernet3/0/8 not found in array
XXX: Looking at iface FastEthernet3/0/9
XXX: line 'FastEthernet3/0/9 unassigned YES unset down down' is down
XXX: FastEthernet3/0/9 not found in array
XXX: Adding FastEthernet3/0/9 to ports array
XXX: Looking at iface FastEthernet3/0/10
XXX: line 'FastEthernet3/0/10 unassigned YES unset down down' is down
XXX: FastEthernet3/0/10 not found in array
XXX: Adding FastEthernet3/0/10 to ports array
XXX: Looking at iface FastEthernet3/0/11
XXX: line 'FastEthernet3/0/11 unassigned YES unset down down' is down
XXX: FastEthernet3/0/11 not found in array
XXX: Adding FastEthernet3/0/11 to ports array
XXX: Looking at iface FastEthernet3/0/12
XXX: line 'FastEthernet3/0/12 unassigned YES unset up up' is up
XXX: FastEthernet3/0/12 not found in array
XXX: Looking at iface FastEthernet3/0/13
XXX: line 'FastEthernet3/0/13 unassigned YES unset down down' is down
XXX: FastEthernet3/0/13 not found in array
XXX: Adding FastEthernet3/0/13 to ports array
XXX: Looking at iface FastEthernet3/0/14
XXX: line 'FastEthernet3/0/14 unassigned YES unset down down' is down
XXX: FastEthernet3/0/14 not found in array
XXX: Adding FastEthernet3/0/14 to ports array
XXX: Looking at iface FastEthernet3/0/15
XXX: line 'FastEthernet3/0/15 unassigned YES unset up up' is up
XXX: FastEthernet3/0/15 not found in array
XXX: Looking at iface FastEthernet3/0/16
XXX: line 'FastEthernet3/0/16 unassigned YES unset down down' is down
XXX: FastEthernet3/0/16 not found in array
XXX: Adding FastEthernet3/0/16 to ports array
XXX: Looking at iface FastEthernet3/0/17
XXX: line 'FastEthernet3/0/17 unassigned YES unset down down' is down
XXX: FastEthernet3/0/17 not found in array
XXX: Adding FastEthernet3/0/17 to ports array
XXX: Looking at iface FastEthernet3/0/18
XXX: line 'FastEthernet3/0/18 unassigned YES unset up up' is up
XXX: FastEthernet3/0/18 not found in array
XXX: Looking at iface FastEthernet3/0/19
XXX: line 'FastEthernet3/0/19 unassigned YES unset down down' is down
XXX: FastEthernet3/0/19 not found in array
XXX: Adding FastEthernet3/0/19 to ports array
XXX: Looking at iface FastEthernet3/0/20
XXX: line 'FastEthernet3/0/20 unassigned YES unset up up' is up
XXX: FastEthernet3/0/20 not found in array
XXX: Looking at iface FastEthernet3/0/21
XXX: line 'FastEthernet3/0/21 unassigned YES unset down down' is down
XXX: FastEthernet3/0/21 not found in array
XXX: Adding FastEthernet3/0/21 to ports array
XXX: Looking at iface FastEthernet3/0/22
XXX: line 'FastEthernet3/0/22 unassigned YES unset down down' is down
XXX: FastEthernet3/0/22 not found in array
XXX: Adding FastEthernet3/0/22 to ports array
XXX: Looking at iface FastEthernet3/0/23
XXX: line 'FastEthernet3/0/23 unassigned YES unset down down' is down
XXX: FastEthernet3/0/23 not found in array
XXX: Adding FastEthernet3/0/23 to ports array
XXX: Looking at iface FastEthernet3/0/24
XXX: line 'FastEthernet3/0/24 unassigned YES unset up up' is up
XXX: FastEthernet3/0/24 not found in array
XXX: Looking at iface FastEthernet3/0/25
XXX: line 'FastEthernet3/0/25 unassigned YES unset up up' is up
XXX: FastEthernet3/0/25 not found in array
XXX: Looking at iface FastEthernet3/0/26
XXX: line 'FastEthernet3/0/26 unassigned YES unset down down' is down
XXX: FastEthernet3/0/26 not found in array
XXX: Adding FastEthernet3/0/26 to ports array
XXX: Looking at iface FastEthernet3/0/27
XXX: line 'FastEthernet3/0/27 unassigned YES unset up up' is up
XXX: FastEthernet3/0/27 not found in array
XXX: Looking at iface FastEthernet3/0/28
XXX: line 'FastEthernet3/0/28 unassigned YES unset down down' is down
XXX: FastEthernet3/0/28 not found in array
XXX: Adding FastEthernet3/0/28 to ports array
XXX: Looking at iface FastEthernet3/0/29
XXX: line 'FastEthernet3/0/29 unassigned YES unset up up' is up
XXX: FastEthernet3/0/29 not found in array
XXX: Looking at iface FastEthernet3/0/30
XXX: line 'FastEthernet3/0/30 unassigned YES unset down down' is down
XXX: FastEthernet3/0/30 not found in array
XXX: Adding FastEthernet3/0/30 to ports array
XXX: Looking at iface FastEthernet3/0/31
XXX: line 'FastEthernet3/0/31 unassigned YES unset down down' is down
XXX: FastEthernet3/0/31 not found in array
XXX: Adding FastEthernet3/0/31 to ports array
XXX: Looking at iface FastEthernet3/0/32
XXX: line 'FastEthernet3/0/32 unassigned YES unset down down' is down
XXX: FastEthernet3/0/32 not found in array
XXX: Adding FastEthernet3/0/32 to ports array
XXX: Looking at iface FastEthernet3/0/33
XXX: line 'FastEthernet3/0/33 unassigned YES unset up up' is up
XXX: FastEthernet3/0/33 not found in array
XXX: Looking at iface FastEthernet3/0/34
XXX: line 'FastEthernet3/0/34 unassigned YES unset up up' is up
XXX: FastEthernet3/0/34 not found in array
XXX: Looking at iface FastEthernet3/0/35
XXX: line 'FastEthernet3/0/35 unassigned YES unset down down' is down
XXX: FastEthernet3/0/35 not found in array
XXX: Adding FastEthernet3/0/35 to ports array
XXX: Looking at iface FastEthernet3/0/36
XXX: line 'FastEthernet3/0/36 unassigned YES unset down down' is down
XXX: FastEthernet3/0/36 not found in array
XXX: Adding FastEthernet3/0/36 to ports array
XXX: Looking at iface FastEthernet3/0/37
XXX: line 'FastEthernet3/0/37 unassigned YES unset down down' is down
XXX: FastEthernet3/0/37 not found in array
XXX: Adding FastEthernet3/0/37 to ports array
XXX: Looking at iface FastEthernet3/0/38
XXX: line 'FastEthernet3/0/38 unassigned YES unset down down' is down
XXX: FastEthernet3/0/38 not found in array
XXX: Adding FastEthernet3/0/38 to ports array
XXX: Looking at iface FastEthernet3/0/39
XXX: line 'FastEthernet3/0/39 unassigned YES unset down down' is down
XXX: FastEthernet3/0/39 not found in array
XXX: Adding FastEthernet3/0/39 to ports array
XXX: Looking at iface FastEthernet3/0/40
XXX: line 'FastEthernet3/0/40 unassigned YES unset up up' is up
XXX: FastEthernet3/0/40 not found in array
XXX: Looking at iface FastEthernet3/0/41
XXX: line 'FastEthernet3/0/41 unassigned YES unset down down' is down
XXX: FastEthernet3/0/41 not found in array
XXX: Adding FastEthernet3/0/41 to ports array
XXX: Looking at iface FastEthernet3/0/42
XXX: line 'FastEthernet3/0/42 unassigned YES unset down down' is down
XXX: FastEthernet3/0/42 not found in array
XXX: Adding FastEthernet3/0/42 to ports array
XXX: Looking at iface FastEthernet3/0/43
XXX: line 'FastEthernet3/0/43 unassigned YES unset down down' is down
XXX: FastEthernet3/0/43 not found in array
XXX: Adding FastEthernet3/0/43 to ports array
XXX: Looking at iface FastEthernet3/0/44
XXX: line 'FastEthernet3/0/44 unassigned YES unset down down' is down
XXX: FastEthernet3/0/44 not found in array
XXX: Adding FastEthernet3/0/44 to ports array
XXX: Looking at iface FastEthernet3/0/45
XXX: line 'FastEthernet3/0/45 unassigned YES unset up up' is up
XXX: FastEthernet3/0/45 not found in array
XXX: Looking at iface FastEthernet3/0/46
XXX: line 'FastEthernet3/0/46 unassigned YES unset up up' is up
XXX: FastEthernet3/0/46 not found in array
XXX: Looking at iface FastEthernet3/0/47
XXX: line 'FastEthernet3/0/47 unassigned YES unset down down' is down
XXX: FastEthernet3/0/47 not found in array
XXX: Adding FastEthernet3/0/47 to ports array
1287181296Process Forced Exit- MAXRUN timer expired.
("foreach" body line 1)
invoked from within
"foreach line [split $result "\n"] {
set line [string trim $line]
regsub -all {\s+} $line " " line
set elems [split $line]
set iface [l..."
invoked from within
"$slave eval $Contents"
(procedure "eval_script" line 7)
invoked from within
"eval_script slave $scriptname"
invoked from within
"if {$security_level == 1} { #untrusted script
interp create -safe slave
interp share {} stdin slave
interp share {} stdout slave
(file "tmpsys:/lib/tcl/base.tcl" line 50)
Tcl policy execute failed: 1287181296Process Forced Exit- MAXRUN timer expired.
LOG FILE:
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/1 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/2 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/3 unassigned YES unset down down
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/4 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/5 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/6 unassigned YES unset down down
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/7 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/8 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/9 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/10 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/11 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/12 unassigned YES unset down down
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/13 unassigned YES unset down down
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/14 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/15 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/16 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/17 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/18 unassigned YES unset up up
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/19 unassigned YES unset down down
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : OUT : FastEthernet1/0/20 unassigned YES unset down down
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : CTL : 20+ lines read from cli_read, debug output truncated.
Oct 16 08:21:37: %HA_EM-6-LOG: tm_suspend_ports2.tcl : DEBUG(cli_lib) : CTL : cli_close called.
I have a feeling its truncating the good stuff. Is there a way to make it output everything and not truncate the rest of the lines or is that what the onscreen stuff from above is?
10-15-2010 03:38 PM
10-15-2010 03:47 PM
The XXX output:
XXX: Looking at iface FastEthernet3/0/48
XXX: line 'FastEthernet3/0/48 unassigned YES unset down down' is down
XXX: FastEthernet3/0/48 not found in array
XXX: Adding FastEthernet3/0/48 to ports array
XXX: Looking at iface GigabitEthernet3/0/1
XXX: line 'GigabitEthernet3/0/1 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet3/0/1 not found in array
XXX: Looking at iface GigabitEthernet3/0/2
XXX: line 'GigabitEthernet3/0/2 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet3/0/2 not found in array
XXX: Looking at iface GigabitEthernet3/0/3
XXX: line 'GigabitEthernet3/0/3 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet3/0/3 not found in array
XXX: Looking at iface GigabitEthernet3/0/4
XXX: line 'GigabitEthernet3/0/4 unassigned YES unset administratively down down' is admin down
XXX: GigabitEthernet3/0/4 not found in array
XXX: Looking at iface EBN-23002-3#
XXX: Line 'EBN-23002-3#' is not valid
10-15-2010 03:54 PM
10-15-2010 04:08 PM
10-15-2010 04:55 PM
10-15-2010 05:01 PM
The original script is still on the switch. I loaded the old .bat file but it didn't disable the ports. So I will wait until tomorrow to see what happens. Should I take all but the original script off the switch or can I leave the debugging script with the XXX outputs on there?
10-15-2010 05:04 PM
If you take the latest script with the XXX code, copy .dat file from a few days ago, and run the script, the ports should shutdown. Alternatively, you can load the latest script I just sent with all of the debugging removed, wait until tomorrow, and all of the down ports should be shutdown.
10-15-2010 05:13 PM
Ok. I copied the .dat from a few days ago and ran the XXX script and got this in the log but still didn't shut down. I will load the script that you just posted and wait until tomorrow unless this output tells you anything:
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet3/0/9 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet2/0/20 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet2/0/21 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet3/0/47 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet2/0/22 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet3/0/48 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet2/0/23 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet2/0/25 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet2/0/26 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet2/0/27 since it was last used on Tue Oct 12 00:00:01 guam 2010
Oct 16 10:03:37: %HA_EM-6-LOG: tm_suspend_ports4.tcl: Shutting down port FastEthernet2/0/28 since it was last used on Tue Oct 12 00:00:01 guam 2010
10-15-2010 05:04 PM
I just checked the log and go this: It looks like its trying to disable the ports but it doesn't.
10-15-2010 05:50 PM
Re-enable "debug event manager tcl cli", test the script, and post the output.
10-15-2010 05:57 PM
Here it is: This is just a snippit. I was going to take out the {} but I didn't want to screw up the script.
Oct 16 10:54:20: %HA_EM-6-LOG: tm_suspend_ports4.tcl : DEBUG(cli_lib) : IN : EBN-23002-3(config)#{interface FastEthernet2/0/27} shut
Oct 16 10:54:20: %HA_EM-6-LOG: tm_suspend_ports4.tcl : DEBUG(cli_lib) : OUT : ^
Oct 16 10:54:20: %HA_EM-6-LOG: tm_suspend_ports4.tcl : DEBUG(cli_lib) : OUT : % Invalid input detected at '^' marker.
Oct 16 10:54:20: %HA_EM-6-LOG: tm_suspend_ports4.tcl : DEBUG(cli_lib) : OUT : EBN-23002-3(config)#
Oct 16 10:54:20: %HA_EM-6-LOG: tm_suspend_ports4.tcl : DEBUG(cli_lib) : IN : EBN-23002-3(config)#{interface FastEthernet2/0/28} shut
