02-27-2022 03:48 PM
I need help understanding how to configure these drive to be how this picture shows. I have added the packet tracer plus the configurations for the devices.
Solved! Go to Solution.
02-28-2022 01:18 PM
here is your network (saved in PT version 8.1). The configuration in the text files contains a lot of errors, I had to change a few things (interfaces etc.).
02-28-2022 12:50 AM
the attached file you sent is almost empty. What specifically do you need help with ?
02-28-2022 07:05 AM
02-28-2022 07:37 AM
did you get it configured correctly in the meantime ?
02-28-2022 08:38 AM
02-28-2022 01:27 AM
02-28-2022 09:38 AM
So the networks that are show on the picture where do those get applied too and how would I connect the devices to one another?
02-28-2022 10:11 AM
sorry for asking stupid questions, but what is your experience level (with Packet Tracer), that is, do you know where to find the cables ? And do you know how to transfer a configuration from a text file to an actual device ?
02-28-2022 11:48 AM
02-28-2022 01:18 PM
