08-29-2019 06:47 AM - edited 08-29-2019 06:49 AM
Hi community!
I have a Cisco Smart Software Satellite(Versio 6.3.0)
It seems to me that the Synchronisation ist not working anymore/hanged up
The Synchornisation is still running since 4 days and does not finish
In the Firepower Management Center the Licenses are shown correctly but I get following error message
I have checked the ports on the firewall and i pinged the cisco cloud server. Both are ok
Has anyone an idea?
Solved! Go to Solution.
02-24-2022 11:37 AM
You need to update your FMC, some root CA certificates have been decommissioned.
https://www.cisco.com/c/en/us/support/docs/field-notices/721/fn72103.html
09-02-2019 07:57 AM
As I read this info you should have synchronized before 25-aug-2019, but that did not succeed
so on 28-aug-2019 smart license authorization expired.
i'd check under button "actions" if you can kill the current synchronization and start a new one
02-24-2022 11:37 AM
