isaacalves27
Beginner
Smart Install - Hostname
Hello again
I am now struggling with a new issue. I would like the SI to give a different hostname to the host (one less parameter afterwards). I have checked and it is possible to use option 12 of the DHCp server but I am not being able to configure it properly.
I would like SI to give fx
Hostname SW12 to the switch with the ip 10.0..0.12
Hostname SW13 to the switch with the ip 10.0.0.13
Hostname SW13 to the switch with the ip 10.0.0.14
And so far...
Is it possible to do smthng like this or am I just dreaming high?
Thanks for all your help
Isaac
1 REPLY 1
isaacalves27
Beginner
Is possible to use an on demand update of the configuration but that times out...
