Hello, Je désire resetter le mot de passe d'un Switch Cisco Cisco N3K(C-31108TC-V). Je n'Ai pas accès au CLI via ssh ou console port. Merci pour vos retours
The content you are looking for has been archived. View related content below.
Hello , Could you help me to reset the password on a Cisco Nexus N3K(C-31108TC-V). I ain't got access to CLI throught ssh or console port
I want to enable SNMPv3 on a Cisco router, v1/v2 is fine but v3 refuses to work. Can you help?
Hello!I have setup lab environment for test rogue on wire solution.List of Devices,- PI 3.10.2- SW C1000 (PoE) - fw 15.2(7)E7- WLC 5520 (Connected to SW C1000) - fw 8.10.162- AP C9120 (Connected to SW C1000) - fw 8.10.162I have plug the rogue AP to S...
I have a couple of Cisco Firepowers that I can access thru SSH or the FDM, but I can't console to them?-Software version: 7.0.5-72-Configured with primary and secondary-Base license-Not using FMCCan someone tell me how to get console access? Thank yo...
Hello Everyone,I'm novice to networking. And below is the requirement I'm trying to figure out. Any leads would be greatly appreciated"You are working as an IT architect for a new startup business that grew faster than expected. they expanded to oper...
I'm having problems setting up my home network using Cisco2921 for the first time. It has the basic licenses only. Below is the running config followed by my adapter settings. Any assistance would be greatly appreciated. Thank you.Current configurati...
Hello,The DISA STIG, V-239941, asks that the following be configured:event manager applet BACKUP_CONFIG event syslog pattern "SYSLOG_CONFIG_I" action 1 cli command "copy startup-config scp://userx:xxxxxxx@10.1.48.10//opt/config_backup" action 2 syslo...
Who do i speak with to make sure the switch is set up to allow communication between the equipment i am installing and the equipment on site.
Hello Everyone,I work in a data center and we have two L3 Nexus 9k cores with 40g ports, then we have ~10 cabinets with 2 top-of-the-rack switches connected directly to the cores. Each TOR has connections for servers, ISP/MPLS routers, etc.I am tryin...
What have I tried?Once I connected the console cable to the router and my system, I checked that the USB port was available in my system and accessible.$ ls -l /dev/*USB* /dev/ttyUSB0 $ dmesg ... [22726.984409] usb 3-3: new full-speed USB device n...
Anybody can help me with this issue on VTP?
We have configured two Lightweight Access Points using a 3504 WLC. Both access points are connected to the WLC, and have been assigned IP addresses through DHCP from the WLC. Both also state they are providing the WLAN we created. Authentication for ...
switch is running in install mode, i can see files in .pkg format. I can't find a good documentation on how to backup the config files, need help.
Hi,We are finding that some router models are more susceptible to CRC increase/snr decrease than others and tend to lose sync more easily especially when it comes down to sudden spikes in crc indicative of REIN/SHINE issues. Im trying to determine wh...
Subject | Author | Posted |
04-18-2024 06:47 AM | ||
04-18-2024 06:42 AM | ||
04-16-2024 04:45 AM | ||
04-16-2024 01:33 AM | ||
04-13-2024 12:00 PM |
User | Count |
7 | |
2 | |
1 | |
1 | |
1 |
