12-05-2018 05:29 AM
Hi everyone,
I'm trying to configure "event notification" by email with my CISCO Prime NMS 4.3.1.
The SMTP server requires to configure authentication method (with login and password) in addition to the server IP address.
How do we add or update the authentication method for SMTP request in CISCO 4.3.1?
Solved! Go to Solution.
12-10-2018 02:47 PM
Solved!
I have finally configured POSTFIX as SMTP relay on CISCO prime Operation System (RedHat).
I defined the relay SMTP IP address on the "event notification" in adminstration tool.
Postfix forwards the authentified notification to the ISP SMTP server's.
12-05-2018 06:12 AM
afaik there is no option for authentication or encryption on SMTP connection .
the configured smtp server can be configured to accept/reject to relay messages based on selected ip-addresses
you can add Prime NMS server here.
12-10-2018 02:47 PM
Solved!
