Highlighted
Enthusiast
SNMP and IP Flow
whats is the purpose of using snmp command alone or using ip flow command alone....or using both commands at a time on router.
snmp-server community public RO
snmp-server community mares1 RW
snmp-server ifindex persist
snmp-server location DXB-DC
snmp-server contact ip-network-support@abc.com
ip flow-cache timeout active 1
ip flow-export version 5
ip flow-export destination 10.1.208.52 9996
2 REPLIES 2
Highlighted
Enthusiast
SNMP and IP Flow
any one there???
Highlighted
Beginner
SNMP and IP Flow
Both these commands are unrelated and each cater to different purposes.
SNMP has a wide variety of uses typically associated with device management on networks. There are many articles about SNMP available on the web.
The "ip flow" commands you have pasted is related to NetFlow. NetFlow is an IP traffic monitoring technology from Cisco (also available with various other vendors) which can help you with bandwidth monitoring and traffic analytics. The commands you have pasted is just part of the NetFlow configuration. Read more on NetFlow from here:
http://www.manageengine.com/products/netflow/cisco-netflow.html
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
Content for Community-Ad
July's Community Spotlight Awards
