SNMP configuration in Cisco ASA 5525x
Bertran2013
Beginner
Beginner
Snmp server is sending to me the next message: "Community with read/write permission required". Please help me to configure read/write permission into communities.
The firewall is ASA 5525x
5 Replies 5
JEFF SPRADLING
Beginner
Beginner
snmp-server community xxxx rw
where xxxx = your read/write community name
The firewall don't accept "rw", that is the problem.
The ASA does not support SNMP write. You cannot configure rw on the ASA. Only read(ro) is supported.
John
**Please rate posts you find helpful**
Thanks for the correction, John.  That actually makes sense from a security standpoint.
Jerry Paul
Beginner
Beginner
Firewall do not allow read/write permissions. All you can do is to set password on different shells of firewall.
Jerry Paul
www.thenetworkhardware.com
