SNMP Configuration question
I have a question.If i have a SNMP configuration in a switch 4510r, is there any posibility to reach the snmp server without the community command and without the server snmp command??????I have only this lines on the configuration.THANKSSS.
snmp-server engineID local 8000000903000025841E8C38
snmp-server trap-source Vlan10
snmp-server source-interface informs Vlan10
snmp-server packetsize 1024
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps syslog
AFROJ AHMAD
HI,
No it's not possible to reach to the SNMP Server without SNMP-SERVER command.
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
If i have configured the communities and the server lines on the device, what could be the possible issue when the SNMP server reach the switch but the switch doesn´t respond to the request, and when i use the command #show snmp, we have an output in this way:THANKS FOR YOUR HELP
switch#show snmp
Chassis:
Contact: GISN Americas Network - tel: 978-858-7000
0 SNMP packets input
    0 Bad SNMP version errors
    0 Unknown community name
    0 Illegal operation for community name supplied
    0 Encoding errors
    0 Number of requested variables
    0 Number of altered variables
    0 Get-request PDUs
    0 Get-next PDUs
    0 Set-request PDUs
    0 Input queue packet drops (Maximum queue size 1000)
145568 SNMP packets output
    0 Too big errors (Maximum packet size 1024)
    0 No such name errors
    0 Bad values errors
    0 General errors
    0 Response PDUs
    145568 Trap PDUs
SNMP global trap: enabled
SNMP agent enabled
SNMP logging: enabled
    Logging to 131.98.27.6.162, 0/10, 34282 sent, 0 dropped.
    Logging to 192.97.141.173.162, 0/10, 1721 sent, 0 dropped.
    Logging to 192.97.141.176.162, 0/10, 1721 sent, 0 dropped.
    Logging to 192.97.141.55.162, 0/10, 1721 sent, 0 dropped.
Arturo
From the output it is clear that your device is sending traps and this indicates that the snmp-server host commands are correctly configured. It does not appear that your device has recognized any SNMP input from the server. I can think of a couple of reasons why this may be the case:
- perhaps the server has not discovered the device? If the server has not discovered the device then it will not send SNMP polls to the device.
- perhaps the SNMP community configured on the device does not match the community used on the server.
- perhaps you have configured an access list to be used with the community and the access list does not permit this server address?
Rick
Rick
