ā05-16-2017 02:59 AM
Hello all,
Is there a way to change the default snmp description field. The description field is not editable by default on the cisco switches and It send the swicth details , IOS version TAC URL .. etc . If I want to control what information will be send and edit this field , how can I do this ? any idea ?
Regard,
ā05-16-2017 10:34 PM
Not possible, from network management and security viewpoint snmp security is implemented (too) by using access lists, so that only network-manager-(hosts) and tools, can issue snmp requests to the switch(es)
(besides using a non-default snmp-community (string ), of course)
M.
ā05-18-2017 07:13 AM
SNMPv2-MIB::sysDescr is a read-only OID.
If you wish restrict its access you could setup ACL with SNMP views.
Look this guide focused on Cisco IOS: Securing Simple Network Management Protocol - Cisco
