279
Highlighted
Beginner
SNMP gets to VRRP MIB on an ASR 920 do not work
Hi everyone,
I'm trying to perform snmp get operations on an ASR920, more precisely on the VRRP. But I've found out that while in other routers (ASR 1001-X, ISR 1100, etc...) the oid 1.3.6.1.2.1.68 works well (VRRP-MIB ), on the ASR 920 it doesnt'. Here are the debugs from an ISR 11XX and an ASR 920:
ISR1117:
ISR1100#snmp get-bulk v2c 10.0.0.1 public timeout 2 non-repeaters 1 max-repetitions 1 oid 1.3.6.1.2.1.68
SNMP Response: reqid 19, errstat 0, erridx 0
vrrpNodeVersion.0 = 1
ISR1100#
*Feb 20 16:24:11.616: SNMP: Get-bulk request, reqid 19, nonrptr 1, maxreps 1
vrrpMIB = NULL TYPE/VALUE
*Feb 20 16:24:11.619: SNMP: Packet sent via UDP to 10.0.0.2.161
*Feb 20 16:24:11.619: SNMP: Packet received via UDP from 10.0.0.2 on BDI783
*Feb 20 16:24:11.619: SNMP: Get-bulk request, reqid 19, nonrptr 1, maxreps 1
ASR 920:
ASR920#snmp get-bulk v2c 1.1.1.1 public timeout 2 non-repeaters 1 max-repetitions 1 oid 1.3.6.1.2.1.68
SNMP Response: reqid 1, errstat 0, erridx 0
nhrpNextIndex.0 = 0
ASR920#
*Feb 20 07:29:19.933: SNMP: Get-bulk request, reqid 1, nonrptr 1, maxreps 1
mib-2.68 = NULL TYPE/VALUE
*Feb 20 07:29:19.936: SNMP: Packet sent via UDP to 172.16.0.1.161
*Feb 20 07:29:19.937: SNMP: Packet received via UDP from 192.168.100.2 on GigabitEthernet0/0/7
*Feb 20 07:29:19.937: SNMP: Get-bulk request, reqid 1, nonrptr 1, maxreps 1
Is there another MIB for VRRP on the ASR920 or it really doesn't exist? Thanks,
Best regards.
José Manuel
Everyone's tags (3)
4 REPLIES 4
Collaborator
Re: SNMP gets to VRRP MIB on an ASR 920 do not work
 - Can sometimes also depend on the software version the ASR is using ; do you have a recent version ?
M.
Beginner
Thanks for the reply,
Well I have a pretty recent version, 3.18.4SP (march 2018). But I have tested some devices on quite older versions and worked fine.
Beginner
Sorry about the late response. I finally opened a TAC case and the engineer confirmed to me that it's not implemented for the ASR 920. Thanks,
Best regards.
Beginner
Best regards.
Everyone's tags (2)
Content for Community-Ad
July's Community Spotlight Awards
