07-25-2007 12:18 PM
I'm trialing solarwinds to monitor my test network here.
I configured the following command on my router:
snmp-server community private RW
In solarwinds, it asks for the I.P address and SNMP Community String.
When I enter the above fields, i'm getting error messages:
'10.0.0.1' does not respond to SNMP Queries using 'private'
Any steps or configurations which i'm doing wrong here?
07-26-2007 07:32 AM
Check if there's any ACL blocking SNMP traffic to the router.
07-26-2007 09:30 AM
Try configuring a RO string as well, and see if that makes any difference.
-J
07-26-2007 11:07 AM
also try to configure the host server
snmp-server host 10.0.0.1 public
That may help
07-29-2007 11:49 PM
Start a snmp debug on the router using the 'debug snmp packet' command. Then fire up solarwinds and try to connect. See if the debug produces any output to confirm that the packets are being received and replies are being sent back. It that looks good, check for any firewall or access-lists blocking the replies on the return path of the packets to the NMS.
