SNMP OID's for FWSM, ASA, ACE and IPS
gautamzone
Dear Friends,
I am trying to take a backup of 13 routers / switches using snmpset, the composition being 1 3750, 4 6500's, 6 7600's , 2 7200's.
I am successfully able to take the backup of the devices.
Here's the command i have used:
snmpset -v 2c -t 60 -c IDCRW -M "C:\mibs" 172.20.1.132 .1.3.6.1.4.1.9.2.1.55.172.16.0.200 s 172.20.1.132
I wanted to know if there is a possibility to also take backup of FWSM, ASA, ACE, IPS using similar SNMP OID's?
Does anyone know the relevant OID's for these devices?
Thanks a lot
Gautam
Joe Clarke
No, the firewall devices do not support SNMP SET operations, and the IPS doesn't support the CISCO-CONFIG-COPY-MIB or OLD-CISCO MIBs.
Joe Clarke
