Highlighted
Beginner
SNMP OIDs to identify port mode setting on 3750, 6509 and Nexus switches
Is there and OID I can use to determine if a port is setup as an access or trunk port?
1 ACCEPTED SOLUTION
Highlighted
Engager
Re: SNMP OIDs to identify port mode setting on 3750, 6509 and Ne
Hi Jeff,
for the c6500 I use CISCO-STACK-MIB::vlanPortIslOperStatus
vlanPortIslOperStatus.13.43 = notTrunking
vlanPortIslOperStatus.13.44 = trunking
and for the Catatlyst 2k/3k CISCO-VTP-MIB::vlanTrunkPortDynamicStatus:
vlanTrunkPortDynamicStatus.1 = notTrunking
vlanTrunkPortDynamicStatus.50 = trunking
! ifIndex
Unfortunately I don't have any Nexus yet.
Rolf
4 REPLIES 4
Highlighted
Engager
Hi Jeff,
! ifIndex
Rolf
Highlighted
Beginner
Thanks these work great.
Highlighted
Engager
Thank you for the feedback!
Does one of this OIDs work for the Nexus too?
Rolf
Highlighted
Beginner
The 3750 one did work for the Nexus. So to answer your question, yes.
Content for Community-Ad
