SNMP Polling not working to Mgmt Station
fhoban
I am having issues getting SNMP polling working from an Arbor device to a cisco GSR. Configuration has been verifed as correct on the arbor box and there is similar working elsewhere in the network. Other snmp management stations can get SNMP info no problem. There is only one hop in between the Arbor mgmt. station  and that is a L2 switch. Cant figure out the problem. I have no access to arbor box currently.Set up as follows.
Arbor CP --> Has 2 interfaces fa2/46 (vlan 98) and fa2/47 (vlan 99) connected to Switch A.
Switch A trunked to Corea A which has dot1q subinterfaces Gi1/1.98 and Gi1/1.99.
Routing etc working fine.
Static ip route to the loopback of the Arbor box redistributed into ospf
Sw A Config;
interface FastEthernet2/46
description *** arbor ***
switchport access vlan 99
switchport mode access
duplex full
speed 100
interface FastEthernet2/47
switchport access vlan 98
duplex full
speed 100
interface GigabitEthernet3/4
description **Trunk to Core A**
switchport trunk allowed vlan 97-99
switchport mode trunk
logging event link-status
speed nonegotiate
Core A Config;
interface GigabitEthernet1/1
description
mtu 1600
bandwidth 1000000
no ip address
no ip redirects
no ip directed-broadcast
no ip proxy-arp
load-interval 30
no negotiation auto
  no cdp enable
interface GigabitEthernet1/1.98
description Vlan to eth0.ddos
bandwidth 1000000
encapsulation dot1Q 98
ip address x.x.x.x 255.255.255.252
no cdp enable
interface GigabitEthernet1/1.99
description Vlan to eth2
bandwidth 1000000
encapsulation dot1Q 99
no cdp enable
Routing for connectivity to Arbor Loopback
ip route <loopback arbor> 255.255.255.255 <eth0 arbor> tag 9999
ip route <loopback arbor> 255.255.255.255 <eth2 arbor> tag 9999
CoreA-the#sh access-lists 2
Standard IP access list 2 (Compiled)
    50 permit 10.10.10.10  -----------------------------------------> Loopback of Arbor device
    20 permit x.x.x.x(17248 matches)
    10 permit x.x.x.x wildcard bits 0.0.0.31
    30 permit x.x.x.x wildcard bits 0.0.0.63 (419508 matches)
    40 permit x.x.x.x, wildcard bits 0.0.0.255 (1081592 matches)
    60 deny   any log (10248 matches)
route-map DDOS_LOOPBACK, permit, sequence 10
  Match clauses:
    tag 9999
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
router ospf 1
log-adjacency-changes
auto-cost reference-bandwidth 10000
redistribute static metric-type 1 subnets route-map DDOS_LOOPBACK
SNMP CONFIG:
snmp-server view noroute iso included
snmp-server view noroute ipRouteEntry excluded
snmp-server community xxxxxxxxx view noroute RO 2
Appreciate the help.
Lets check basic things first.
1. Can you ping Cisco GSR's management's default gateway IP address.
2. Can you ping Cisco GSR's IP address with Arbor's loopback ip address.
I assume, you won't be able to ping in response to point number 2; as if you would have been, then there should not be any problem.
Smitesh
Thanks for reply Smitesh. Pings work fine although the arbor doesnt give an option to specify loopback. TCP Dump from arbor box below.
Source now set to loopback.
Going out to
Using snmp port 161
SNMP community looks ok
BUT
No response and no hits on access list 2
SEE dump below.
Internet Protocol, Src: X.XX.X, Dst: X.X.X.X Version: 4
Header length: 20 bytes
Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00)
0000 00.. = Differentiated Services Codepoint: Default (0x00)
.... ..0. = ECN-Capable Transport (ECT): 0
.... ...0 = ECN-CE: 0
Total Length: 78
Identification: 0x0000 (0)
Flags: 0x04 (Don't Fragment)
0... = Reserved bit: Not set
.1.. = Don't fragment: Set
..0. = More fragments: Not set
Fragment offset: 0
Time to live: 64
Protocol: UDP (0x11)
Header checksum: 0x16f2 [correct]
[Good: True]
[Bad : False]
Source: X.X.X.X
Destination: X.X.X.X
User Datagram Protocol, Src Port: 14650 (14650), Dst Port: snmp (161)
Source port: 14650 (14650)
Destination port: snmp (161)
Length: 58
Checksum: 0x9204 [correct]
[Good Checksum: True]
[Bad Checksum: False]
Simple Network Management Protocol
version: v2c (1)
community: XXXXXXXXXXXXXXX
data: getBulkRequest (5)
getBulkRequest
request-id: 953983092
non-repeaters: 0
max-repetitions: 2
variable-bindings: 1 item
Item
valueType: unSpecified (1)
unSpecified
Smitesh, It was an ACL configured on the GSR under global config ' ip receive-list xxxx'. Never saw this command before and given  the size of the config file never spotted it.
Thanks for your input !
